Sumimasen
- Jun 6, 2018
The tap izzit clean water come out? Then recycle the wash hand water for flushing?Heng I still got photos for the label on the plastic cover.
I not sure leh but think should be ba. When I purchase the top cover, the vendor got unplug the tap and made some changes inside so the water will directly fill up the tank instead.The tap izzit clean water come out? Then recycle the wash hand water for flushing?
should be bahThe tap izzit clean water come out? Then recycle the wash hand water for flushing?
...what other possibilities leh? Flushed water come out of tap to wash hands
Actually the water from the tap so small and dun run long. If I wash my hands with soap, cant wash clean lor.should be bah...what other possibilities leh? Flushed water come out of tap to wash hands
u mean the way flow very slow? Like that takes a long time to wash hands wor. I also dun likeActually the water from the tap so small and dun run long. If I wash my hands with soap, cant wash clean lor.
Yes, slow and small pressure and the running end quite fast. Totally not practical. No wonder newer bto dun have this.u mean the way flow very slow? Like that takes a long time to wash hands wor. I also dun like
Lang bro, your Dell laptop exchange gao tim already?
win liaoI not sure leh but think should be ba. When I purchase the top cover, the vendor got unplug the tap and made some changes inside so the water will directly fill up the tank instead.
win liao
whenever we flush the bowl,the water runs for like a min but we never washed our hands with it ,very redundant feature
Wahh! do u know what caused the spike in consumption?Yes, slow and small pressure and the running end quite fast. Totally not practical. No wonder newer bto dun have this.
I just checked fedex tracking, the wrong laptop was received by Dell in Malaysia yesterday. The new one not yet arrive.
Last month my utility bill shoot up to from $34++ to $46++.![]()
I purchased a cover top to cover it. More easy to wash and can put extra toilet paper on it when need.win liao
The problem is the water pressure is small. I always wash my hand with soap so before I rub my hands with soap properly the water already stop.A min is v long leh
I'm not tall and long enough to wash it there.Good feature. Wash kuku jiao.
My desktop and monitor ba.Wahh! do u know what caused the spike in consumption?
So mischievousI'm not tall and long enough to wash it there.![]()
the bomb shelter rack is up
the mayer hob
a carpenter said this kitchen top has very good quality
lights are up
my mum is going to tear down the wardrobe as she needs a bigger one
lights are up
