No smell…, the switch all stayed up. I didn’t do anything and the power came back on like really a few seconds latergoto ur MMCB box ... open it ...
give it a good smell .... smell anything funny?
It's called a voltage sag or dip, it's a short momentary loss of supply which is not very critical unless it's like semi conductor industry which is intolerable for such dip then they will install devices to ride through this dip.… at like almost same timing. It just went off for a few seconds then come back on again.
What could be the cause?
The circuit breaker inside house did not trip at all, all the switches were up
no trip is dangerous, can die one, do a trip test, if no work, must get electrician
but happened yesterday and today like almost at the same timing.It's called a voltage sag or dip, it's a short momentary loss of supply which is not very critical unless it's like semi conductor industry which is intolerable for such dip then they will install devices to ride through this dip.
Not sure if it gonna happened tomorrow again when no one is ar homeI also say it’s something similarsomeone turn on some high power electrical device.
timing? just now?… at like almost same timing. It just went off for a few seconds then come back on again.
But did your circuit breaker trip? Mine just stayed up and the power came back literally in seconds without me doing anythingI also say it’s something similar
ts, sic you our story. Rast time we also often had power trips.
one day, this *ahem* device spoilt.
we realised this device was the culprit cos wif this device gone we never had power trips anymore.
So ts, look for a “ahem” type or no-brand appliance that is always in use.
Happened like half an hour ago. The power actually came back on in less than 10secstiming? just now?
any construction or electrical work downstairs?
a few seconds? how many seconds?
ts case never trip anything is scary man...I also say it’s something similar
Yesterday and today holiday, didn’t see any electrical work going on outsideauto come on by doing nothing ?
maybe someone outsai eg sp power / town cowcer doing some work
Very strange behavior.But did your circuit breaker trip? Mine just stayed up and the power came back literally in seconds without me doing anything
No leh, didn’t switch on anything at that time. Funny thing is it happened yesterday at like similar time too. Yesterday I just thought it was a power dip so wasn’t really bothered, then it happened today againts case never trip anything is scary man...
later something starts burning...
the highest current is usually the storage heater...
but i believe switching it on normally doesn't cause such a scenario, right?
