Power trip two days in a row
David Lai
Happened like half an hour ago. The power actually came back on in less than 10secs
this sounds funny man... if it happens again and someone in the household happens to noticed it, do give sing-power a call... if no one at home, maybe can make sure equipment that may be sensitive to surged power be left off for the time being...
eno_lc
Yah, cos tomorrow working no one at home. A bit worried :s13:
David Lai
No leh, didn’t switch on anything at that time. Funny thing is it happened yesterday at like similar time too. Yesterday I just thought it was a power dip so wasn’t really bothered, then it happened today again :spin:
sorry ts, was just commenting that normal household electrical equipment shouldn't be causing such scenario as yours...
alchemist_acid
are you using anything or leaving them on standby?
aircon, water heater, water kettle, oven, PC desktop etc?
DragonFire
As others have mentioned, probably a brownout. Report TC ask them to check the flat’s electrical distribution system. Eapecially if neighbours experienced the same. Brownouts are super rare in Singapore. Even more so in HDB where there is a medium tension substation in every block.
Might be a neighbour on the same circuit powering up something really big, but not big enough to trip the overload breaker.
Big motors and transformers usually to blame.
Motors found in big AC, some high powered cleaning equipment. Large capacity transformers found in high end hifi, IT equipment.
danguard
… at like almost same timing. It just went off for a few seconds then come back on again.
What could be the cause?
The circuit breaker inside house did not trip at all, all the switches were up
check your appliances mabbe have a faulty one
eno_lc
I see, so TC is the one to call? If it happens again tomorrow then I’m gonna call them
eno_lc
In that it should have tripped the circuit breaker first? Mine was like the power just came back on in a few seconds without me doing anything… Any way I will try just turn off those appliances not using and see
DragonFire
Should be same agency you call if there is a pump room water leak. Best to verify with neighbours if they saw what u saw.
Don’t say trip. Say power interruption. It is important to emphasize the power came back without you doing anything.
standarture
You got high current devices? Aircon, heater, oven, microwave, hair dryer etc.?
Any non safety mark devices?
danguard
play safe ba oh wells
blackestvoid
check if sum device turned off/on at that timing
most likely caused by a change in current/voltage consumption
eno_lc
The only thing I had on at that time was fridge, router and fan etc. Nothing high current
