Which one will you pick? TV or Projector
The_King
My usage is mainly is movies, gaming, tv show. which one will you pick?
projector pros: bigger screen at least 110inch , cheaper at >$1.5k
projector cons: noisy fans, the heat from the lamp, need a dark room or dim room
Tv pros: picture quality, room of any lighting
Tv cons: expensive, smaller screen
Clearnfc
It depends alot on what you want and your room configuration.. I have both...
A TV for shows and projector for movies and games... Yes, it's huge and awesome.
Heat and noise is never a problem... The lamp is jsit 200+w, it's not like you put the projector right beside you. Mine is ceiling mounted.
The_King
i can only have one a 65inch tv cost at least 1.6k
Clearnfc
https://shopee.sg/product/17628187/7755811853?smtt=0.292233705-1658706867.9
Closest I found so far you can consider
then fan noise is negligible unless you are sitting directly with head beside it.
but 1500 ANSI only so you need ALR solution for screen.
else wait for laser 4k projectors to come out
beware, once you go projector you’ll never go back.
1500 lumens is a bit low... You will need a very dark room.
But why would anyone spend $2k on this?? Go for better brands.
Yueming
Daytime close the blinds lor
TS budget 1.5k leh :o
Which better brand offering > 1500 ANSI UHD/4K ?
SecretAgent
if you compare a same size to size tv vs projector... definitely tv.
if you just want size, go for a projector.
_hulk_
Tv for day and most nights.
Projectors for some nights.
