I think these are non-PWM ones right? But they are still good.recently changed my case fans to arctic p14
got the 5 pack bundle from amazon for relatively good price earlier this year but too lazy to change
yeah non PWM since I'm hooking them up direct to the PSU anywayI think these are non-PWM ones right? But they are still good.
I think the price of the P12 5 piece pack was 35 bucks last week. This was about the price I paid for the 5 piece pack a few years back. But now its back to inflated prices.Few months back amazon was selling P14 PWM PST 5 piece pack for only S$5X.
Towkay, 2 questions.Because I owned a scythe fuma 2 so I just go with the wonder snail to form a complete scythe theme cpu cooling.![]()
How many RAM slots does it obstruct?
If i still remember, on load it was around 5-7 drop (IIRC). But i really do not think you need to change the stock fan on the Fuma 2 Rev. B since they are already very good.Towkay, 2 questions.
1. What‘s the temperature improvement from stock to a pair of Wonder Snails on the Fuma 2 rev. B?
2. How many RAM slots does it obstruct?
Gamxia.
Heya! 5-7°C is substantial. What load was it on? I.e. CPU wattage and app used? It is similar to Hardware Canucks’ and Kleo Yan’s findings.If i still remember, on load it was around 5-7 drop (IIRC). But i really do not think you need to change the stock fan on the Fuma 2 Rev. B since they are already very good.
If you use the stock fan, it should clear all 4 rams slot. If you replace the front slim fan, you will take up 1 dim slot. But, if you use low profile memory, then just move the fan slightly upwards.
Hmm okay, thank youNot recommended. Use the same fans to daisy chain.
If you're using the Y Splitter it is possible but take note the MB will only send 1 signal to both fans which will be based on the percentage of the max rpm that the fan is rotating.Quick question on case fans.. If I have a Noctua A12x15 and A12x25, can I daisy chain them and plug into the same motherboard header? These are for top exhaust fans
Yup exactly, no harm since Noctua fans are relatively low power. Typical recommended fan header limit is 1A.OK, yes using the y-splitter and they're both the PWM versions so the MB would regulate the speed of both based on a fixed percentage, correct? There's no risk to doing so was what I'm asking
No risk. just make sure the slower fan is the one the mobo fan header take reference from.
I ordered from Amazon US together with my Noctua c14S cooler. Cheaper but my build is waiting for its delivery, supposed to be by 2 AugNoctua fan are like RTX now. Crazy expensive.
