jinsatkilife
- May 4, 2019
when will they make the legendary national day promo great again?
Not surprising actually. Most people will not buy a 3+ K laptop under normal circumstances. I ordered a Legion 7 with the RTX 3080 config as well last year in May because it was so difficult to buy a desktop GPU. Even if you can find it, it cost so much, that the RTX 3080 or even the RTX 3070 itself is worth the price of an entire laptop. Good thing was I cancelled my order a week later because the waiting time was also quite long, i.e. 2 months approx, and the prices of GPUs were coming down a little.
Yes, and I noticed that Lenovo's site tend to change this surreptitiously. So for those that skip customization because the pre-assembled ones look cheaper, please be careful. Otherwise if your 2 to 3+K laptop goes bust just after a year, you are on your own.3 years vs 1 year warranty care is a lot of differences actually.
i hope they do...when will they make the legendary national day promo great again?![]()
Generally, higher resolution should come with better display specs (my assumption). You should check things like brightness and color accuracy, etc.anyone knows what is the difference between the P16s and T16 AMD ?
also which is the better display?
16" WQXGA (2560 x 1600)
16" WUXGA (1920 x 1200)
and refresh rateNot only screen size…
Screen brightness also impact battery
Perhaps some may find low res displays acceptable.I don't think you will be using it at max brightness most of the time when you're outside if you're only on batt, unless you're outdoors under bright sunlight.thanks for the feedback.
on lenovo website the higher resolution 16" WQXGA (2560 x 1600) is cheaper by $10 to the lower resolution 16" WUXGA (1920 x 1200).
both are 400nits
Alright here comes the codes! (All still valid at time of this post)
[Best of the bunch: these 2 codes give different discounts for different models]
BIRTHDAY
LIMITEDTIME
[Others]
Coupon1
Coupon2
Coupon3
Coupon4
Coupon5
Coupon6
Coupon7
CHECKOUT
COMEBACK
DONTMISS
THANKYOU
EXCLUSIVE
HZCNSALE
MASTERCARD5
SHOPBACKAMD
YAHOO
Shopback3 (stackable with Shopback cashback 2.5-5% but may still work out to be less than some codes above)
Need to enter the codes as shown i.e. upper- / lower- case letters. Also, student discount (additional 5%) is stackable with promo codes, provided that you're able to open a student account / have an email account from an educational institution.
Happy shopping!
Thanks for sharing.Hi guys, me again, just did my research about the current promo codes as I was getting another Lenovo laptop. Here to share again!
Best of the bunch: LIMITEDTIME
[Others]
FRONTLINER
THANKYOU
DONTMISS
CHECKOUT
SHOPPINGSPREE
DOORBUSTER
THINKELITE
BUT, try to also speak to their online agents! Some (unfortunately not all) of them are really helpful in getting quotes for you after you create a saved cart for them to work with. The quotes they give can be cheaper than any of these promo codes! Plus, these quotes work as "eCoupon", so I suspect that they are compatible with ShopBack too (as opposed to the promo codes above)!
Also, student discount (additional 5%) is stackable with promo codes and quotes, provided that you're able to open a student account / have an email account from an educational institution.
Happy shopping!
Thanks for sharing.
I am looking at yoga 7 gen 7 AMD and Yoga Slim 7 X Pro... Or maybe even the upcoming Thinkbook 16p gen 3. The prices are very high and the coupons you shared are useful but not great. Still miss the IPRICE30 discount.
