Using SBJUL18 and $10k as an example: http://www.ilovessb.com/swap/SBJUL18/10000 , I personally would not swap because:
- Up until Jul 2023, the profit only gets as high as $4, but if you consider the cost of swapping ($2 to redeem, another $2 to apply), then there is no profit at all.
- From Aug 2023 onwards, you lose more and more. It doesn't make sense to swap SBJUL18 with SBOCT22.
Firstly what a great job done by hwckhs! If I understand correctly, you can only compare with what you have on hand currently. So based on SBJUL18, you can only compare till it matures in JUN28.
ah, sorry I didn't see the horizontal axis (timeline) ends at the earlier issue. so yep it only compares when there's both holdings at the same time. thanks!
