[Software Update] iOS 16.1.2
Jeremy1
I hope Apple will make an update on the IOS to totally disable the Wifi or Bluetooth directly on the drag down menu and not from the Settings.
I ever highlighted this to one of the Apple Salespeople but he told me it's doesn't cause any problem which I feel likewise as it will drain battery and cause network issue sometimes if you don't disable on your settings menu and just on your drag down menu.
szeli
my wifi, bluetooth always on. haven't seen it drain any batt. most of e time it's rogue apps that drain batt for me..
Jeremy1
Logically it make sense it will take battery life cause you are always searching for wifi n Bluetooth network.
Another thing is sometimes it will cause internet slow connectivity because of this.
I feel they should do the same as what they did on the mobile data.
And with current cheap data plan, most will likely not used Wifi nowadays.
tohchr
I used iOS shortcut app to switch off WiFi. Just a touch of a button and my WiFi is off.
TrueBeliever_jh
Have you measure how much battery drain is the bluetooth causing~?
https://discussions.apple.com/docs/DOC-12271
https://www.macrumors.com/guide/ios-battery-tips/
2. Limit Apps Using Bluetooth​
iOS 13 introduced a feature that lets you know when apps have requested Bluetooth access, and there are a surprising number of apps that want to use Bluetooth for things like location tracking with Bluetooth beacons or scanning for Chromecast devices.
Jeremy1
Sorry, I didn't.
I usually will just go setting and off it although it's a bit troublesome.
szeli
IOS shortcut app 🤔
bought a few nfc tags recently. I setup a simple automation to enable e wifi toggle when I get home. sometimes I toggle wifi off on mrt cos of e bad wireless@sg then forget to switch wifi back on when reach home. now just scan e nfc tag will do.
if u also have smart home stuff can auto trigger them. maybe that’ll be my next project 🤔
TrueBeliever_jh
Speaking of shortcuts
Home App Automation was not working on the first 2 nights when im arriving home.
A bit odd when the Scene didn't kick in.. seems fine so far.
Anyone else experience the same issue~?
Jeremy1
I am going to write in to Apple and suggest to them on the IOS request.
Hopefully they will listened to my suggestions 🙏
TrueBeliever_jh
Jirachi
WestGuy
Yesterday my phone just froze at the always on display. Phone will ring but screen not responsive. Had to hard reset.
Also battery life is definitely not as good as my 13PM
Oppa380
Try restart phone
