Xiaomi Mi 10 and Mi 10 Pro
TUV2008
Si beh suay, hand itchy go and upgrade to 12.5 CN ROM and the notification problem again… feel like throwing the phone to Singapore river now.
hkchew03
Hi,
Any recommendation place for repair of screen blackout.
Thanks
If you are adventurous enough, just get a screen and back replacement, worse come to worse is break both while doing replacement. Internally not so easily to break as long as you are careful.
Ctrl_Alt_Del
After updating I seem to lose google play store, anyone has the same problem? TIA.
No problem with mine, maybe try to install the play store app again.
Read on xiaomi forum some people encountered no phone signal, had to factory reset to solve the issue.
animeonegai
Noticed one issue with the new update. The bluetooth will ownself turn on. Even though i didnt turn it
Ctrl_Alt_Del
When bluetooth is turn on then turn off using the pull down control panel, it is not actually totally turn off. Pop up a message " all bluetooth devices will stay disconnected today". The bluetooth control panel button remains grey color. Then the next day or reboot phone the bluetooth will auto turn on.
Need to tap and hold on the control panel bluetooth button to enter the bluetooth settings to totally turn off. There is a toggle in the bluetooth setting additional settings to always show status bar icon.
animeonegai
Actually is need go to the inside setting to turn it off.
TUV2008
Can someone teach me how can I delete all the photos under a whatapp chat at one go? Right now I can only select one by one to delete. How come cannot select all?
really frustrated with the new OS.
yakman
Clear all data from your phone app management
TUV2008
my Mi10 pro is china ROM, version 12.5.10, last two days the google play store keep crashing, cannot use, despite i restart the phone still the same.
if i unistall the google play how can i reinstall back again?
PES1989
1st option: Side load with APK version of the Google Play Store from Apkpure website.
https://m.apkpure.com/google-play-store/com.android.vending
or
2nd option: Download Playstore from GetApps.
or
3rd option: Install Google Installer APK
https://www.techbout.com/install-google-play-store-on-xiaomi-phones-20192/
