BradenHeat
- Apr 4, 2005
@BradenHeat has an interesting perspective as well for BTO flats --- where wireless backhaul may be an easier option compared to using a router in the DB box, at least when you have already bought a pair of Asus Zenwifi XT8.
That being said, Zenwifi XT8 2-pack is probably not a good option in the first place. The better option is to have two LAN ports in the living room and then use dual band Asus routers using AImesh. The problem is probably many people do not have two LAN ports next to each other in the living room.
https://forums.hardwarezone.com.sg/...us-zenwifi-xt8.6177953/page-59#post-139565366
Wah lao eh, i thought i kena NTUC points la sia, suddenly got quoted. lol
Anyways to add on :
just get a single ax82u,
if those 3room long style, can get 4out of 5 bars, from living room to furthest room with bare minimum line of sight interference
[ in non geek speak, router sees your furthers room where you stand, and you can see the router eye to "eye""]
the wireless backhaul is technically, better, due to the fact, some of the older / non 5GHz capable wireless "smart "" iot or devices might have a better latency.
long distance single router
vs
mesh via 2nd 5Ghz radio transfer
my reason --> 2 mesh devices, with a wireless back haul, shorter distance, can push more stable 5ghz /2.4ghz if required, with the 3rd radio active as backhaul
only applicable IF,
- single ax82u [ yes, i know its expensive, but ive been testing with long walkways, its given the best bang for buck performance ive been going around helping extended family relatives ]
- LAN cabling is for sure NOT doable, as with some of the pre 2013 btos, those rooms are only with useless phone lines, thus re-wiring work has to be done BEFORE move in [ duh ]
again, Ubiquity and/or other cheaper solutions or higher end ideas that have been thrown around, has been here free of charge
but , again,
im coming from a [ set and forget it , but easy to maintain] , by non technical users [ thus Access points are out ] , remote work that can be done through phone is near nay impossible for other brands [ Linksys / netgear etc has poor management interface , unless cost is problem aka getting a 2nd hand linksys mesh ]
not sure if Orbi Mesh has improved , but currently ive yet to hear a single complaint from xt8s introduced,
though i was itchy to help them upgrade to merlin firmware lol
