Gaming PC advise
thepasarmalamshop
Looking to DIY a gaming PC and have been reading some of the recent threads.
Shortlisted some of the items
Pricing from Dynacore price listPrice
Motherboard + CPUWhich MB and CPU ? AMD or Intel ??
CPU CoolerScythe Fuma2 Rev.B Kaze Flex ii Tower Heatsink83
Graphic CardPowercolor Amd Radeon Hellhound RX 6600 8GB GDDR6465
RAM DDRG.SKILL TRIDENT Z RGB 3600MHz CL18 (aura sync) 2 x 16GB199
SATA M.2 SSDWd Black SN770 5150MB/s Gen4 Nvme M.2 SSD(5 Year)158
Internal HDDNot Needed
CasingLian Li Lancool III RGB White TG Casing225
Casing Fanincluded with Casing
Power SupplyLeadex iii SuperFlower 750W Gold Full Modular145
PC will be used for gaming and work. Budget range between 1.7K to 2K
Which MB and CPU to go for? Intel ?AMD ?
Which monitor for 4K gaming?
Appreciate the help.
NightRaven49
at the lower end (<$500), both will offer a similar level of performance. if looking to save a buck and not intending to upgrade soon can go amd, 5600 non x + cheap b550 can go as low as 39X. 12400f + decent b660 board is a little bit more expensive at 4XX, but (should) have the option of upgrading to 13th gen in the future. 5700x and 12700f combos do also fit into ur upper budget limit of 2k; they will offer similar gaming performance with a 6600, though the 12700f pulls ahead in some productivity workloads like 3d rendering and the adobe suite.
i would also suggest getting the 6600 from bizgram, they have a gigabyte model going for 3XX. the casing is a little too expensive for my taste, but if it has some usp that appeals to u then bopian. otherwise looks good.
Phen8210
i think go for 12400f first then next time upgrade the CPU, spend the rest of budget on GPU.
thepasarmalamshop
Thank you gurus for the advise. Sound like 12400f + decent b660 is the way to move forward.
As for the Casing , this is more for my boy who like RBG :D
How about for monitor ? Is Prism 4K good to move ahead ?
NightRaven49
can just get a cheaper casing and add rgb fans/strips. can replace the cpu cooler fan with rgb ones also.
prism is ok for the most part but i wouldnt recommend it due to the relatively poor quality of panels used. u can consider from this video from 8:11:
6600 will struggle at 4k gaming though, its more suited for 1080p to 1440p.
Kunkka
lancool ii cheaper i have that quite good/
Phen8210
If you want something with RGB out of the box, consider Phanteks G360A, which comes with 3 preinstalled ARGB fans. It's priced at SGD 135+, I believe.
Nah, avoid prism.
Also, you need a more powerful GPU to have a smooth 4K gaming experience. 4K monitors are expensive too. Combining these two is likely to burst your budget.
thepasarmalamshop
Nah, avoid prism.
i guess no need 4K ba... just a normal gaming PC for him will be good enough.
thepasarmalamshop
Thank you Sir
