No. VoNR support only on M1 I think. But device specific yes.VoNR supported by all 3 telco on 5G SA network but phones dpendent?
Not Singtel.VoNR supported by all 3 telco on 5G SA network but phones dpendent?
You need to enable in settingsMy Poco F4 GT works on M1 NR SA network but not VoNR....
Enabled VoNR. Device just show VoLTE on status bar.You need to enable in settings
VoNR uses the same IMS switching system as VoLTE so it might still show VoLTE. Try making a call on 5G and it shouldn't drop to LTEEnabled VoNR. Device just show VoLTE on status bar.
It did drop to 4G+ lol sadlyVoNR uses the same IMS switching system as VoLTE so it might still show VoLTE. Try making a call on 5G and it shouldn't drop to LTE
A firmware update might have broke 5G. StarHub is still running NSA so I think Samsung broke itBeen using 5G NSA for ~1 year on Starhub with my Samsung A52 5G (which is on their "supported devices" list). Always assumed it wasn't certified for SA yet. Since about 2-3 weeks all 5G service seems to have disappeared. Phone will only connect to 4G. Starhub support is useless as always, anybody any idea what might be going on (have they switched off NSA?) Or suggestion on how to fix this?
Worked perfectly fine for 3 weeks straight in Thailand, on a freaking prepaid SIM. I think our telcos are a mess...5G is a mess.
5G is a mess.
main 5g vendor-supplier in Thailand is Huawei with around 60% market share, followed by EricssonWorked perfectly fine for 3 weeks straight in Thailand, on a freaking prepaid SIM. I think our telcos are a mess...
micro managing supported phone models (or worst, the firmware on them) in order for 5g to work on a certain network is just a sure-fire recipe for screw ups
with huawei's 5g modems in phones almost non existent thus negligible today, all 5g radios are either from qualcomm or mediatek, though there are different models / generations within each brand, the difference between are definitely minor, how difficult can it be for telcos to provide support to just 2 brands?
Not Singtel.
Becuase Singtel has no VoNR. Only Starhub and M1I do not see any VoNR and only VoLTE for my Realme X50 5G on Singtel SIM Only Plus plan (three months free 5G access). Anyway, I think my phone does not support VoNR anyway.
