Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
temytemy
Where do you guys order case and screen protector? Mine still stuck in China :')
I using some brand from China but not so good. Wanna change to Nanotech.
For case, I use Spigen for now. I find Ringke Fusion X good but haven't released for P7 models.
lyk13
Yes. It stalls at the facial recognition. According to Singpass help desk, it is an issue with Android 13. Works fine on Android 12
As if facial recognition isn't the only thing....Their setting up also a little unstable. Hope it's their issue then they can rectify m
Im not planning to use singpass on this device tho...hmmm
garychengjw
maxshield case + hydrogel arrived from china
ringke matte case stuck at korea
waiting for my $250 and will hoot casemate and bellroy case from google site.
crow_nest
What charger adapter for USB-C are you guys using? Need to buy official google one?
No need official. Just use any modern USB charger will do. Preferably one with 30W charging and has PPS support because thats what the pixel phones use. Any compatible USB type C PD cable will do as well. I recommend Ugreen or Baseus for charging peripherals. Built very well and will handle any device you throw at it.
xiaoren03
Just ordered Nanotech sp and china hydrogel this morning... only next week then can receive it.
Case is Case-Mate Tough Clear Case for Pixel 7 Pro from google store.
Vulpix
Moderator
Moderator
I bought my favourite Ringke brand. :s13: Probably coming next week.
kryptonit3
I actually find the fingerprint scanner on Pixel 6 Pro quite ok. And it has reportedly been improved over time with software updates. Are you comparing to the stock Pixel 6 Pro as shipped or one with the latest software installed?
I’m actually curious how the camera compares on the 7 Pro vs the 6 Pro. If difference is marginal, may not be worthwhile getting the 7 Pro.
royfrosty
5G is working for M1 Network. Type - 5G SA.
Also VoLTE works well.
crow_nest
Anyone's whatsapp not sending the sound notifications? Like the notification is still there, but the screen doesnt light up when msg come in and it does not play the notification sound at all. happens regardless of whether your screen is on/off at the time. I already checked and double checked my whatsapp notification settings and they are all in order. And oddly enough ot only seems to be whatsapp. Instagram, discord, carouhell, SMS, Gmail, all seems to be fine. Not sure if its a bug with the phone.
Ted100
Was at Courts Heeren earlier today. They would not give me the $50 discount unless I actually traded in an old phone. I think someone posted yesterday saying he got the $50 without question. Maybe my bad luck and got a super strict salesperson.
I also asked if I could stack the Courts online PWP promo (buds pro for $167) with their roadshow promo (free Fitbit) and the answer was no.
