Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
Advancer
What’s the best deal for pixel 7 and 7 pro right now? Feel like getting one to play.
or should just go with the pixel 6a to save some money?
I was using s22 then decided to buy pixel 6a to play play. End up I like it so much that I sold my s22.
Today just unbox my pixel 7 and don't think I can go back to 6a liao. Hahaha
simpleton
Anybody wanna pre order the twin pack wsd from direct? Gian the camera back protection leh haha.
6pcs with shipping divide out is around s$33/piece. Ships out 17 Oct onwards.
I dont mind sharing. You good at application? Hahaha
lyk13
If can get you home then it's not so much an issue because can use charger liao.
Better yet just get the pixel stand and place it on top so can charge without having to keep plugging it in and out.
I started using Qi Charging with Nexus 5, horrible experience back then. The phone would be super hot....
Now these kind of wireless charging no longer like that le right?
royfrosty
Anybody knows how to set Routines to trigger via location basis?
Online search says that there should be a location trigger. But I can never find it.
Loser
Yeah I hope so. Haven't been using qi chargers but it had time to improve since nexus 5, can go see reviews on the pixel stand 2 for example.
anthonygreenisreal
Man bro, don’t liddat me, I just placed order for 6a an hr ago. Should I just cancel and then go for the pixel 7 sua? But the 7 is like x2 the price of 6a now.
lyk13
The free VPN actually not available in our region? Can't see any options related to it.
(Forgot to reply to this earlier....)
Google One VPN is not available in Singapore. Thus, Pixel 7 and 7 Pro users may not get it as currently stands. I have talked to a support person and for now, there is no link between the Pixel 7 series and Google One VPN being made available separately by device availability. Thus it is tied to that support region country list and Singapore is currently still not on it.
While the world was raving about wireless charging, I've been through and done that and returned from hell of it...so...LOL.
You must have your decisions to go 6a and not 7. So just stick to that. You don't get swayed so easily. And price is your factor from your reply.
Yongkit
You can find it in the routine setup as following circle option
jikilan
I bought the pixel stand 2. It is actually an auto paired device. Will based on the changing profile u set to charge your pixel. There is some AI there (and also based your sleeping/charging time), to prolong the battery life or temperature and control the internal fan inside the stand.
I have question on other mid range qi charger, good to use? Or all qi charger same same 1? Just without fan and control?
Cos can't afford to buy multiple pixel stands in different locations...:cautious:
lyk13
I have question on mid range qi charger, good to use? Or same same all qi charger same same 1? Just without fan and control?
Android 12 and 13 has Adaptive charging, so that 'AI' might just be the OS. Not the stand.
anthonygreenisreal
Totally, I just wanna get a cheap Android phone to play around. My main thing is still iPhone pro
Advancer
Just go with your own budget.
I see that the pre order deal for pixel 7 is quite good now with the $250 google credit.
But the pixel 6a is definitely a good work horse too. Value for money at $500ish.
Yongkit
This doesnt trigger based on location. If u click in, i believe is u need tell google assistant "im home"
Samsung one can detect your location and perform actions that u set
You are right maybe my routine too simple basically when I return home when my phone detect the wifi it will auto mute my phone
