Iceman127
- Jan 24, 2010
Thanks a lot, your advice really helps. I wasn't aware of CGNAT until i came upon this thread reading.I will go for Starhub and not MyRepublic if you want to choose between the two, since MyRepublic is now under Starhub and it uses CGNAT. The other choice is M1.
As for secuity all three should be similar. It is up to you to implement good security for your home network. The ISPs are pretty much the same even some of them offer add-on subscriptions for home network security (in general not very good solutions).
I shall go with Starhub then.
