Sony Xperia IV
rssd21
1ii no more updates since jun22! boycotting sony please
samsung even updating a52.
disappointed samsung surpassed sony in updates.
Only android updates can make you so mad to compare with substandard phones. :s22:
Any security updates will also not keep your phone 100% safe anyway, most will just need common sense and discipline to safeguard their phones from hackers and viruses.
Fyi, I stopped buying flagship phones of any brand since the prices started to get more expensive than my PC.
Go ahead and buy anything you like, no need to bother with sony phones if you are so upset. :s13:
Toader
Swapped to myrepublic 5g sim card. Now using successfully and waiting for number to port over! Still haven't seen 5g yet. Will do speed test and post when have 5g signal. :spin::s13::spin:
Toader
5g areas quite scarce. IT seems other telco setup so early also more me LTE reception...
But I managed to grabbed a chance and did speed test.
After I reboot my phone the 5g networks seems to spring up more . Either that or SG open up the 5g?
darkmatt
see my article above..
mortpenguin
8 months after getting this phone and several updates later, my camera still freezes once in a while. Nothing can be tapped on the screen and I have to do a hard restart by pressing both volume buttons and the power button.
Anyone else has the same issue?
Toader
DID you turn on VPN and left it running? Mine is ok.
ranchy
It only happen once for me. Was taking photo then suddenly hang there. Have to force restart. Then the file taken was corrupted. Gave me a scare.
Hope it won't be a common issue.
rssd21
I guess there might be some background apps or function running that interferes with the camera, since the camera app takes quite a huge toil on RAM.
A few times when my android phones (xperia or others) hang, it is due to the google backup app running in background. Not sure if this is common for android phones.
ranchy
Hmm okay... Hope it's not a common issue then...
Oh yah, can I check with all, do you all have Netflix on your Xperia IV.?
Somehow , my wideline is L3 now. I remember mine wasn't L3 before..
Mine is hk set.but should have issues with L1 issues
eS.KuKu
just checked mine is L1, SG set though
