大蛇丸 Orochimaru
- Mar 31, 2015
They got so many skyscraper, Jin scary Sia.. if happen. I rmbr go there look all building so high high duno why they need to do that they got so much land...quite common in bolehland right
Yes. Florida.Happened in 2021?
I think not. It was uncontrolled water/salt damage.Iirc there illegal construction for that condo, nvr properly calculate the weight.
Last statement is applicable for both HDB & private condo?Yes. Florida.
In the US, Condos are a lot older in many cities. Our condos aren’t quite as old, but some are getting there.
Just so you know if an inspection declares a building here unfit for occupation, the owners are on their own.
Condos mainly. HDB I think will find alternative accommodations for tenants.Last statement is applicable for both HDB & private condo?
From what I read, waterproofing failed on the pool deck. Prolonged water infiltration and sea salt caused the slab to fail. Slab which supports the garage and the collapsed tower.Actually what caused this?
Oic. So people GG really suay sia.From what I read, waterproofing failed on the pool deck. Prolonged water infiltration and sea salt caused the slab to fail. Slab which supports the garage and the collapsed tower.
.Need to rematch the YT video again.I think not. It was uncontrolled water/salt damage.
