- Sep 16, 2018
Can advise, my contract with starhub is ending this March and am tempted to switch to Singtel as been having problem with wi fi in our rooms. Our router is in the living room, bedrooms is blocked by walls, using google wi fi extenders which does not really help that much. Not that tech savvy so not really familiar with router brands but willing to do research and learn what is best for a faster internet in the house. Appreciate comments.
DO not consider Singtel because of the use of ONR. They also come with lousy wireless routers.
You should stay with Starhub but go with the better router. You need to post the floor plan with the location of the ONT and existing Google Wifi units so that people can recommend the setup. Do you have LAN port in the rooms?
If you would like to go with Starhub provided solution, usually 2 unit of Linksys MX4200 should be good enough for most users. But if the placement is not ideal, three units may be required.
