S23 accessories discussion
born to die
anyone can recommend the cheapest screen protector that is non-hydrogel and no liquid involved.
itchying
I used ringke fusion matte for 3 days, not bad. Now keep back in box because use Samsung cases liao. Letting go on my carousell.
Y u use samsung hard clear case? Better than ringke? Thought too tight can scratch yr phone ?
angel99999
I have the UAG Civilianfor S21,the are really heavy. Now got to be more cautious in choosing UAG case.
Sent from NNNPNT !
Unless one is quite clumsy or may have kids who would drop the phone, I wouldn't think UAG suits everyone. But I must say I was taken in by the design, really unique and nice looking case with layers of details, just not a fan of the bulk. If using the normal S23 or S23+, might be better.
superio
So sorry if this has been asked/answered before,
Can anyone recommend the smallest and most compact charger plug that can charge S23 Ultra with Super Fast Charge 2.0?
Thank you!
ahbao
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.2dd52e8dn900fn&id=697236971820&_u=d28gi5bbae8b
Sharing this screen protector, very easy to align and apply. Looks a bit soft at first, but once cured with UV, it behaves like the default Samsung screen protector (at least the one that come w Samsung phone last time). When you peel off got the satisfying ripping sound effect. No rubber peel effect. s pen works well, at first I thought still rubbery but I realised it's because the pen tip is soft lol. Only thing is you need to make sure all the sides etc are pasted down properly before you use UV to cure. If not once it hardens, there will be bubble/ cannot stick properly
Thanks, got this and so far so good
keemmeng
I don't see this Spigen case being stocked in local accessories shop, even those that carry Spigen brand..it was in Flossy Carter's YT S23U review video. Anyone seen it so far?
Read HWZ Forum Rules!
cloudangel
Sent from NNNPNT !
The S23U is by default itself is already quite heavy and bulky. So i would appreciate a UAG case which might be bulky but gives me a better grip.. im currently temporarily using a Spigen liquid air for now and it doesnt feel as safe holding it even tho the case is definitely lighter and less bulky than the monarch pro which i ordered.
trenzterra
No stock right now according to Tech House NEX. Anyway, you can just buy the normal one then paste your own ring... same effect.
Having used the Liquid Air, Ringke Fusion and Ultra Hybrid, my fav is still the Ringke. The Ultra Hybrid is very heavy compared to last year's version (increased by 5-7g). Liquid Air is ok but the sides are rounded so a bit hard to grip.
My only complaint about the Ringke is the sides are a bit loose.
Waiting for my Ringke Fusion Bumper. Hope it's better.
Loser
Have you tried the ultra hybrid with the black tpu sides for S23U? Is it slippery?
trenzterra
Yup I'm using the one with black tpu sides the matte black back. It's quite slippery (compared to the fusion) but the back has some grip so it compensates somewhat.
Loser
Have you used the thin fit before on your phone?
I find the material quite grippy dunno if it's the same as your case.
Loser
$100 only because mine is s23 purchase. The s23+ I sold is of course sold the vouchers together.
You're a great flipper seller la that's why I support you one.
But then you got the e-voucher instead of reward points?
