Desktop 2.0 & 2.1 speaker discussion thread VI [consolidated]
dreamaurora
Anyone using schiit loki mini+? Any good? Want to use it with klipsch the fives.
Fives already have EQ by app. If you are using desktop you can even further EQ through desktop apps. Loki Mini+ seems to be redundant unless you have a very good external DAC that has no built in EQ.
GotBetrayed
Should be good for gaming.
Nobody considering the Elipson Facet? Absolute Sound dropped the price for all colors to $999 now so it’s same price with the Fives.
Yes now thinking of adding subwoofer. Either Klipsch SPL-100 sub or svs sb 1000 pro
dreamaurora
Yes, but I have never bought a wired sub before. How to connect btw? Using rca cable?
Depend on your setup.
If you are using the Fives as AlO, you need to get a RCA cable with 1 male to 2 males.
If you have a sound card or DAC with RCA out that you want to connect to the Fives, then some subs like SB1000Pro offer an RCA pass through. Then in this case you need 2 sets of RCA cables. DAC connects to subwoofer then connects to speakers.
GotBetrayed
Just using fives with pc desktop, no other dac. Fives usb connection to pc direct.
so in this case, I need rca cable with 1 male to two males.
any recommendation on which shop to buy Svs sb 1000 pro in sg?
dreamaurora
Think all around same price. The main dealers of SVS i think are Kec at Adelphi and The Expert Group at Funan.
If you go to Expert Group, they also carry B&W and I think they are still clearing their B&W subwoofers at 1.5K each. Might want to consider that if you want to top up a bit.
GotBetrayed
Thanks! Yeah I think Klipsch sub not worth it. Rather get more well established subwoofers like SVS. Haha no need B&W sub too, I don’t like that brand
dreamaurora
Haha, keep an open mind. I don't like B&W sound too but I know people who love it. There are some lesser known brands that can give you very good sound for not a lot of money.
GotBetrayed
Haha yes, too bad in sg hard to demo the sub with my fives. So can only base on online reviews etc
Charles_Chi4
Recently I bought topping e50 to try and it's not to my liking. Wonder if I can change it with eq haha.
Is there any free eq software in windows that is good?
dreamaurora
I don't use EQ software, but Spotify, Tidal, and Roon all have built in equalizers if you want to adjust the sound.
Think the DAC in the Fives is decent. I tried all these Topping, SMSL, they are certainly better onboard sound, but I think to have significant improvement than what you have now must go at least to the entry level R2R DAC like Denafrips Pontus II or Musician Pegasus.
LiLAsN
You have a few ways to do this.
1) This is the cheapest option. You will need to get a Umik-1 microphone and use a free software like REW to calibrate your speakers.
And then use a free software like Equalizer APO and load the calibrated file to it and then run all the audio in your system through and send it to your Sound Output device on Windows.
2) Second option is, you can buy a miniDSP 2x4 HD where you can upload your calibrated REW file (via a UMIK-1 calibration) into so you can run it via your lineout or headphone jack from your PC and use a 3.5mm to RCA cable to your miniDSP device and then have another RCA to RCA cable to run into your DAC/AMP or Active Speakers.
2) Third option is to buy miniDSP DDRC-24. This is the same device as option 2 but with Dirac Live Room Correction filter inside. And as per normal, you will need to have a UMIK-1 microphone for the Dirac calibration and then just upload the calibrated filter into your miniDSP device. And the setup is the same as in option 2 on how to run the cable.
Options 2 and 3 gives more flexibility in that you can use it for other connections and not just limited to PC. And you can also buy the cheap miniDSP 2x4 HD used from Carousell and then opt to buy the Dirac Live upgrade on the website to get Dirac onto that miniDSP 2x4 HD if you so choose. So there's a lot of flexibility that comes with it.
All 3 of these options are running on on calibration softwares that are using Parametric EQs. Meaning, they do a full tweaking to all the frequencies of your speakers. Unlike our typical EQs that only allow us to customize certain frequency ranges. So REW and Dirac Live are 2 of the most powerful Parametric EQ calibration softwares that you can ever have for your speakers and/or headphones.
LiLAsN
I have audition klipsch the fives. They are decent but something seems missing. Is like the clarity and sound stage wasn't very clear.
My intention is to put the speakers at my living room. The size is about 20m2, inclusive of dining area.
I'm thinking of getting Ls50 W1, as it is cheaper than Ls50 W2, and pair it with a sb1000 pro.
Any comment or suggestion? Or any alternative setup?
Just whacked Klipsch the fives just now. Hope Zai for desktop use. Mainly for gaming
Do upgrade the firmware on the Klipsch The Fives. It will introduce a newer EQ which will actually give you a flatter curve than the original Flat EQ that it runs on.
Originally, the Flat EQ gives you a U-shaped curve. Which means, the bass and the highs will drown out the mids. So the audio in the mids will sound quieter than the highs and bass.
The Bass-Cut EQ actually gives you a flatter bass and mids. But the highs are still overall too loud and thus in this mode, you might find the audio to be a bit too tingy. But this is better as it is so much easier to Parametrically EQ the highs to be lower than it is to lift the dips (speaker flaw) in a graph to be higher.
For BanEle. As for positioning, rule of thumb is to always position the tweeters of the speakers to be at ear level and at least pointing towards your ears. Frequencies produced by the tweeters are very directional. That is why when you see a graph, they also show the lines like Early Reflections as the further away you are from the tweeters of your speakers, the lesser you can hear the highs of that speaker. Thus, leading to why you think there's a lack of clarity to the highs. The frequency curve will take a dip downwards very quickly and far down at more than -6dB even. Thus attributing to the lack of clarity further as the volume for the highs are too low to be heard other than the sweet spot. Thus, leading the advice by dreamaurora to toe-in the speakers towards your listening position.
Here's how the frequency curve of the Klipsch The Fives look on both the Flat EQ and Bass-Cut EQ. And for your interest in the KEF LS50 Wireless series, here's the graph for the Wireless 2.
This graph shows where you might be missing any details in the sound if you see the frequency go below the bottom blue line or if your entire sound frequencies are being overpowered by the very loud highs. Anything above or below the desired line shows where a Parametric EQ can be applied to balance out the sound of the speakers.
In comparison, this is how the KEF LS50 Wireless II looks like.
With these 2 graphs, what you ideally want is a speaker that doesn't have any of the frequency response line being outside of the blue line. That is the ±3 dB window. Anything beyond it is either too overpowering to the other frequencies or are too soft to be heard that the other frequencies in the audio will overpower that part of the sound with its loudness.
So if you are able to be in that sweet spot, the KEF LS50 Wireless 2 will be the better option. Not to mention, KEF has a tweeter in the middle of the midrange woofer (which is ideal for many reasons including time alignment which increases your perception of a wider soundstage) as it means you will have a wider sweet-spot than a traditional 2-way driver speaker layout where it is trying to match the mid-range woofer with the tweeter towards a certain position. This in turn means you will get a wider soundstage and clarity with the KEF LS50 Wireless 2. Do remember to pair it with a great subwoofer and you will get the ideal audio experience possible. Do go back for a second listening session taking into advice asking them to use the Bass-Cut EQ on The Fives and on positioning the Tweeters of both speakers towards your ears so be able to really tell the difference between the 2 speakers. KEF LS50 Wireless 1 will be a bit worst. So do try to find a graph for it to have an idea how it compares to the other 2 speakers I mentioned as well.
If you find that the speakers are bass-shy, no worries. A flat/neutral curve will have that kind of feeling for us. Harman Research has shown we like our bass to be more pronounced and tactile. So you can ideally set your subwoofer to be about +4dB or +5dB louder than your speaker volume and it will not drown out your other audio frequency. You'll have to compare between the 2. Though with a Parametric EQ, you want it to ideally have a downward slope as opposed to a hard crash of difference in volume. So there's that. But I'm sure you'll find that sweet spot. No worries! Have fun!
Apologies GotBetrayed for my mixing of advice for him and you into 1 post. 😅
GotBetrayed
For BanEle. As for positioning, rule of thumb is to always position the tweeters of the speakers to be at ear level or at least pointing towards your ears. Frequencies produced by the tweeters are very directional. That is why when you see a graph, they also show the lines like Early Reflections as the further away you are from the tweeters of your speakers, the lesser you can hear the highs of that speaker. Thus, leading to why you think there's a lack of clarity to the highs. The frequency curve will take a dip downwards very quickly and far down at more than -6dB even. Thus attributing to the lack of clarity further as the volume for the highs are too low to be heard other than the sweet spot. Thus, leading the advice by dreamaurora to toe-in the speakers towards your listening position.
This graph shows where you might be missing any details in the sound based or if your entire sound frequencies are being overpowered by the very loud highs. Anything above or below the desired line shows where a Parametric EQ can be applied to balance out the sound of the speakers.
So if you are able to be in that sweet spot, the KEF LS50 Wireless 2 will be the better option. Not to mention, KEF has a tweeter in the middle of the midrange woofer (which is ideal for many reasons including time alignment which increases your perception of a wider soundstage) as it means you will have a wider sweet-spot than a traditional 2-way speaker layout where it is trying to match the mid-range woofer with the tweeter towards a certain position. This in turn means you will get a wider soundstage and clarity with the KEF LS50 Wireless 2. Do remember to pair it with a great subwoofer and you will get the ideal audio experience possible. Do go back for a second listening session taking into advice asking them to use the Bass-Cut EQ on The Fives and on positioning the Tweeters of both speakers towards your ears so be able to really tell the difference between the 2 speakers. KEF LS50 Wireless 1 will be a bit worst. So do try to find a graph for it to have an idea how it compares to the other 2 speakers I mentioned as well.
No worries, updated the firmware since I got it. Sounds quite good and not thinking of whether I should add a subwoofer or not. Mostly for music and pc gaming only.
dreamaurora
Often, speakers that are less neutral and not measuring well can be more attractive depending on our sound preference.
I remembered last time when I demoed LS50 Meta and GoldenEar BRX, both were very good, but I much preferred the sound of BRX. I preferred sound that has more forward mid with sparkling high, so even though Meta was overall more balanced in sound, I found BRX more satisfying to listen, despite it being badly reviewed by ASR.
It's true that seems like most people would prefer more bass in their sound because vocal sound sexier and more soothing, that is why a lot of high end audiophile stuff tend to be on the warmer side.
