ApeTruelove
- Oct 5, 2009
Go for Legend walker and you will not regret.
Any model to recommend?Go for Legend walker and you will not regret.
The one I am still using now no longer in their catalog already since I purchased almost 15 years ago. Hard to recommend you since I do not know what you are looking for. I can only say their hardcase really very durableAny model to recommend?
You can try Chiang Kong Services Pte LtdAny place in Sg where we can replace luggage wheels at a reasonable price?
it's very easy to remove and replace them yourself. the wheels are pretty cheap from shopee, lazada and aliexpress.Any place in Sg where we can replace luggage wheels at a reasonable price?
Ok. I will watch some YouTube video to see if I am up to it.it's very easy to remove and replace them yourself. the wheels are pretty cheap from shopee, lazada and aliexpress.
It's just unscrewing the screws, take out the old wheels, putting the new wheels into place and then screwing the screws back.Ok. I will watch some YouTube video to see if I am up to it.
To be honest, wanna open or steal not very hard de. The main thing is just preventing quick access to ur items ba.Those luggage with zip.. Easy to open with pen?? Haha..
Just notice my super old but good eminent don't have zip one..
nv see this brand before ...Hi all,
My Vietnamese friend is looking for a luggage brand called "Crown" (Taiwan brand) .
Before she comes to SG, I am helping to check on her behalf, which place in SG sells this brand.
Can I pls check is anyone familiar with the brand Crown and suggest where in SG is a good place to check for its availability? Thanks!
Hi Harky,nv see this brand before ...
i tot tw is Eminent
Eminent can go the travel store but quite exHi Harky,
Thanks for yr reply.
Can I pls check, where can I find this Eminent luggage in SG? Thanks!
Thanks again!Eminent can go the travel store but quite ex
I was looking thru the sales when i purchase mine last year. Metro had them, taka had them. but the cheapest place i bought was in lucky plaza. Cant rem its lvl 1 or 2. its the 2nd floor from the bottom (Assuming mcdonalds is the lowest).No Lojel sales recently....
