Comparison of SIM only plans - Part 2
barnabaskoh
Earlier I read if we are in Malaysia and we call roaming partner,it's deducted from our idd free time? So the idd free time can use for both call to Malaysia from Singapore and call to Malaysia when we are at Malaysia?
keenklee
IMHO.
Interesting... which post did u read from? My understanding is that there is no roaming for Heya.SG. 🤔
zzxxzzxx
Simba TPG
While In Malaysia (Roaming under Partners):::
1. Calls to and from SG Mobile numbers, Unlimited Free.
2. Calls from SG Home Line numbers, Free.
3. Calls to SG Home Line numbers, deduct from your free minutes.
4. Calling Malaysia number, I'm not sure.
5. Answering any other countries calls, Free.
Paiseh.i was referring to simba
This is the one I was referring.
What I think you're referring to, is IDD Calls to Malaysia using SIMBA TPG plan. $18/$25/$13*
Simba MY130 ($13*)
Can I use my SIMBA Super IDD Pack overseas?
1 month ago Updated
Yes. If you are traveling to any of the 21 Destinations, you may make calls to the local number and outgoing minutes will be deducted from this 300 IDD minutes. Do download SIMBA Voice App to call.
All plans with IDD supports up to 21 countries (300 mins), except the $13 plan (130GB+10GB Malaysia Data) that only supports IDD to Malaysia (100mins).
barnabaskoh
So if at Malaysia and the local shop or business call me and I answer the incoming call will be free? That's great! Must it be via simba voice app?
zzxxzzxx
Usually Malaysia side Won't call your Singapore number. Due to overseas call rates.
But when you are overseas, you do not need to pay for answering calls.
One easy way to confirm, is to have $0 in Wallet. And try answering calls.
If you are able to make/answer calls in SG without VOICE APP. You can carry on to do so while overseas.
SIMBA TPG - ROAMING VOICE CALLS AND SMS
Voice Calls
Download SIMBA Voice App to make and receive calls overseas seamlessly.
1. Calls to and from Singapore do not have additional roaming charges.
2. Outgoing calls to any Singapore mobile number is free, while outgoing calls to a Singapore fixed line will be deducted from the plan’s Local Fixed Line Minutes allowance (Please add +65 if you are making calls to Singapore while roaming)
3. Outgoing calls to local numbers of the destination you visit is supported. You can either purchase a SIMBA Super IDD Pack or deduct from SIMBA Wallet based on prevailing IDD rates.
vsvs24
Simba is really good for roaming. I normally buy overseas sim card when I am overseas. Was in HK that requires real name registration. Somehow my registration was unsuccessful. Had to rely on Simba's free 1GB for the first few hours until I get to hotel to use their wifi to keep trying the registration.
Simba roaming speed is good in Malaysia and Hong Kong.
barnabaskoh
Thank you!
zzxxzzxx
Actually thinking about it....
Those in business with SG side de Malaysia residents, should find a way to get $5 senior plan or even pay $10 for the normal plan. Where they can legit call and receive SG numbers for free.
Even suitable for any other countries that can have uses for it.
swanky
Singtel have a senior plan offered for their existing customers above 60 yrs old
$10.10 4G Sim only plan (12mths contract)
150mins talktime
100 sms
10gb data
12 mths free caller id
after 12 mths will be $20+5.4(caller id)= $25.4/mth
data drop back to 3 gb
zzxxzzxx
Ok. Emailed SIMBA TPG regarding voice calls.
They support up to 124 destinations for Roaming (and data roaming).
As long you have VoLTE coverage over there, you Do Not Need to have Data Roaming to have Voice Calls and SMS.
Voice Calls (Incoming)::
1. All voice calls are FREE
Voice Calls (Outgoing)::
1. Calls to SG Mobile - FREE
2. Calls to Fixed Line - Deduct from Bundle
3. Calls to IDD (1 or 21 Countries) - Deduct from IDD Bundle or Pay As You Use (Main Wallet)
IDD::
$18 SIM-Only130 :: 300 Mins
$25 SuperRoamMax :: 300 Mins
$20 SuperRoam50GB :: 300 Mins
$30/90Days* ($39/90Days)
SuperRoamMY :: 100 Mins (MY only)
SMS (Incoming) :: FREE
SMS (Outgoing) :: Not Available
Data Roaming::
1. Free for Up To 57 destinations (Group A)
2. Deduct from Main Wallet (10mb block)
Shutterbox
imagine your travel period crosses the billing cycle date, you effectively have 2GB data roaming to cover.
thats pretty sufficient for up to 1 week trip, assuming you can tap on local wifi
zero90
Giga, Simba (TPG) or Vivifi, which one has better coverage and reception?
i stay at cck area.
anthonygreenisreal
i stay at cck area.
So far to me vivifi seem to have the best real world coverage and reception. It is not the fastest though.
Starhub/giga seem to be faster in terms of speed But the coverage not as good.
for SIMBA, it is sometimes patchy and can lose signal on and off once i a blue moon and then the speed is slower than vivifi and giga
