- Jul 29, 2003
Ok, I think the network up liaoI think RedOne network could be down again![]()
one of the drawbacks if you want to port in / out to another telco .. the $10 sim is hefty !almost went with redOne for the sg/my data... but quite turned off with the $10 sim fee.
If you frequently more than once a year sure it might be a turn off. For me I don't switch unless there's significant savings or networks issues, it wasn't too big a deal for me when I jumped to RedOne.almost went with redOne for the sg/my data... but quite turned off with the $10 sim fee.
roam on .. you in malaysia will be log to cellcom .. roam off no data only detect network .. unless you use alot videos in malaysia 20gb is alot of data depends on the amazing plan you took...Just wondering; inside the app (top right) it show Roaming:On
Does this mean if i go MY it will automatically switch (and switch back when I come back?)
Also is there a way to toggle it on and off?
Also for redone, if exceed the limit for the plan, will they kiap the service or just charge extra automatically?
the options is on your mobile under mobile networks for android, not on app for redoneAlways good practice to off roaming in Singapore
How to off? there seems to be an option to disable in Value Added Services -> Manege Your Add Ons but I scared if turn off there cannot on again![]()
2 different things. Disabling the roaming under the phone mobile networks is not 100% foolproof. Many data points that show there will be some data roaming 'leakage', usually end up costing $1-2. Only sure way to prevent this is to switch it off at telco side, usually using the app or calling into customer service. I personally experienced this recently because I forgot to disable it.the options is on your mobile under mobile networks for android, not on app for redone
Can a senior help me with the bill payment matters?
1) Does redone automatically deduct from the balance? If no must I pay myself on the 14th by pressing the pay bill button?
2) Is my April bill paid? I see some credits
3) What does the ($16) mean? I have $16 in my prepaid balance?
I'm using the $8 plan and YES, you can receive SMS while overseas.Does wow 10 plan able to receive Banking OTP while in oversea ? since its mean for local use.
or do i need to buy roaming and turn on roaming in my mobile phone in order to receive OTP?
I also see a balance in Parentheses on my account, namely from "credit adjustment - being CA for waive sim card fee due to VC Promo".... The figures in brackets should be a credit balance??? Same when you over paid your credit card bill, wait for 1st May to see I guess.Can a senior help me with the bill payment matters?
Yes very huge changes! Roaming Downgrade!Heard huge changes coming up in the month of May!![]()
Super 8 plan?Yes very huge changes! Roaming Downgrade!
What happens if u use over 1GB Malaysia.
- 8GB for Local Use. Basic Internet at 512kbps thereafter.
- 1GB for Use in Malaysia. No basic Internet.
as stated, its $0.00 charges
