CPU no Light on
harky
By right most Intel chip (except "f" variant cpu) have integrated internal GPU or iGPU should be able to display the windows but not for gaming purposes.
Too old.. Don't have Hdmi
i think the md got one vga plug but my monitor cable.... nt same as tht
wongminmin
why u buy 1000watts..... even 850 watts is more than enough.
FSP is value for money, but not as durable like seasonic/superflower.
CPU - hard to spoil
motherboard - easy to spoil after 3 years
psu - random spoil
ram - bsod, won't post
gpu - no display
then only left mobo.
harky
CPU - hard to spoil
psu - random spoil
gpu - no display
hahah
my gpu spoilt before.. change one.
current md is last 8-9yr liao
ronnie_gogs
Seems very likely its a motherboard issue. Also did you try replacing the motherboard CMOS battery. Since its so old maybe the battery died. Cheap to replace and check. If still no boot then probably motherboard is a gonner.
harky
Yes I changed.... Same Lo.
when i push the power button . The gpu power and logo light up... MB chip fan move.. After 5sec it off
while the gpu power light still on so I assume there is power.
but cannot boot up.
86technie
but cannot boot up.
Take out each of the RAM and try again.
PC that old DDR3 can prone to failure.
harky
this one i try liao
i got 2 ram.. got 1 is RMA before one... haha
so try both... all result same.
so another i can try is bring my graphic card to my bro house and try... see isit the card issue.. but i guess i had to change my mobo lor :(
wrt54gs
CPU - hard to spoil
psu - random spoil
gpu - no display
Superflower only provides 5-years warranty for all PSU. but FSP G Pro 1000W model has 10-years warranty.
you can get details from Tech-dynamic which support superflower and FSP.
