[No referrals] New MVNO - China Mobile CMLink Singapore
Klein
Hi, does anyone know what are the CIS benefits? And does anyone have referral code?
Not much.
CIS Benefits
- Extra 10GB local data × 12 months
- Extra 50mins local voice x 12 months
- Extra 50 local SMS x 12 months
- Extra 50mins IDD call to 6 selected destinations × 12 months
BombVoyage
hi folks, anyone know any way to get a china mobile number in SG? need a china number for verification to create account..
Not sure if anyone has tried this one.
https://www.cmlink.com/sg/en/1-card-multi-number/https://www.cmlink.com/sg/system/zh...tiple-Number-Service-terms-and-conditions.pdf
2.1 Product Description
(a) You can link your existing active CMCC and/or CMHK mobile number and/or apply for a new CMCC and/or CMHK number on website to a CMLink Singapore number.
(b) Only one CMCC and one CMHK number can be linked to a CMLink Singapore number at any one point in time.
(c) Your CMCC and/or CMHK number must be switched off for the voice call and/or SMS to be forwarded to the linked CMLink Singapore number.
(d) The new CMCC and/or CMHK number applied on website do not have physical SIMs, mobile data service nor the ability to make outgoing calls and SMS.
(e) The forwarded voice call and/or SMS service of the subscribed Product is subject to the Mobile-Terminated voice call / SMS service status of your Singapore CMLink number.
2.2 Eligibility: You are eligible to subscribe the Product if you are an active subscriber of Singapore CMLink service.
2.3 Application: Your application for the Product is subject to Paragraph 2.1 and our acceptance at our absolute discretion.
You will need to upload the front and back of your ID and record a 6-second video holding the ID.
2.4 To link your existing CMCC or subscribe to a new CMCC number, one of the following valid identity documents must
be provided for authentication:
(a) Mainland China Identity Card;
(b) Home Visit Permit for Hong Kong and Macao Residents;
(c) Taiwan Compatriot Permit; or
(d) Passport of any nationality.
386863
am using dis
Aladdin Beast
Can summarize for me? If I get the 12gb plan. I can use my number as it is the data, sms and calls. I can call hk using the sg number.
If I travel to hk, I on my roaming and I can use my data and call using sg line to hk local numbers?
kennyam
In sg - IDD to hk is free. Check the package
In hk - I believe is chargeable
shawnng
Only data roaming is free in HKz
Calling back to SG will be charged as roaming, easily add up to hundreds.
eip1234
Just to add, when you are in HK and call a hk number, this is chargeable. Your calling back to SG is an IDD call.
eip1234
Must say the roaming of CMLink in HK and China is very very very good. 6Gb data per month is enough for me cos there are many many places got wifi.
Also have the Simba to test out; it's hopeless. Both sims were placed in the same phone. The Simba roaming connection in HK (also to CMHK 4G, same as CMLink) was erratic. When it's up and running (lucky huh), the speed was so slow such that it can't even run some of my favorite apps such as CityMapper, WeChat, My Observatory, eSender, Octopus, 中原地圖。
Funny thing is, CMLink is also running on the same CMHK 4G (on the same phone), but fast enough to run all the apps mentioned above. 👍👍👍
vsvs24
Simba signal was very good when I was in HK in Mar. Had to rely on it for one day as my purchased HK Sim card failed real name registration.
Was Simba sim card in Sim card 2 slot ? Maybe next time you try testing signal in SIM card 1 slot. When I purchase overseas sim cards, sometimes instructions say must insert into Sim card 1 slot.
