What PC fans do you use and prefer?
eggy
Yongkit
Psycovirus
are noctua fans worth the money and hype?
yes, if your equipment depends on it. I have 3x noctua AF-12x25s in a server build, running 24/7, cleaned out regularly and not a single one failed in 5 years. Also I have a peace of mind since I don't check the status of the server often.
katata
How do you clean them? just use qtip and rub off the dust and a can of compressed air? Also, where do you buy them from? doesnt seem to be any retailers selling them here
uselessbum
You can buy on amazon sg from Noctua directly, make sure the seller name is "Noctua Cooling Solutions SP". Local retaliers seem to sell at a much higher price even though warranty is still deal with Noctua direct ourselves. I think their stock is also parallel import so might as well buy from Noctua directly.
Psycovirus
The Forbidden Noctua Interview: Fan Engineering Technical Discussion & Challenges - GamersNexus
I would love to summarize to TLDR but it is worth watching fully. Very interesting technical dive into Fan designs and how Noctua takes forever to make a fan.
The fans maybe expensive but they do perform for a very long time. Buy once and forget kind of thing.
I am excited for their new 140mm fan since I am using a 280mm Radiator.
watzup_ken
I used to like air coolers. But over time, the CPU are running hotter and hotter, which resulted in bigger and bigger cooler. The last one that I used was the BeQuiet Dark Rock 4 Pro. It was massive and caused massive obstruction in my system. In short, it was blocking any connectors around the CPU, RAM, and even the GPU (because it was so close to the GPU, trying to get to the locking mechanism of the PCI-E slot is a pain).
