Habrosus
- Jul 23, 2005
First thing that came to mind when I thought I saw that the small pot's just sitting on the drainage plate on the ground, is the TC guys coming round with their soap powder and water hose.the raised pots are for drainage right? initially i had mine just sitting over the corridor drain, but now i have it "raised" over an inverted base plate for pots.
mine is the smallest plant out of all my neighbours, so my pot smaller, but i have larger pots that i can re-pot.
i think i will just give up on this and take a small cutting from my neighbour and try again.
maybe it's because this one was a cutting from my friend, and his growing environment and mine are different, so the plant not used to it? He grow his outside his shophouse, he took over the common area and use it for planting his own plants and he has a 3 meter tall rose TREE
You might want to get a (higher) stand for your next pot.
