Your own capital max 75K. Interest credited will make it exceed 75k but will all earn compound interest daily, 3.48% if you keep in pocket!
If you spend with main account, you can replenish!
Wah, fight Trust gao gao liaoDebit card with rewards coming up!
No issue on my end. Installed and signup using Singpass awhile ago.I downloaded the GSX Bank app. I tried to sign up. The songpass app opens up and then the Singpass app says " you have successfully logged out".
I tried uninstalling and reinstalling GSX. I reboot phone , reinstall app.
Still the same problem. Anybody same issue? Or is it only by invitation to this bank?
No need. I just download the app and install as per instructions given.do we need the invitation??
Yup this is correct. Got to move into the savings pocketsthanks much
so the 3.48% no condition? and first 75k right
You need to be aware they got Main Savings Account and pocket concept. You tranfer monies in and out via the Main Savings Account (only 0.08%). So you need to create pocket and then transfer monies from Main Savings Account into the pocket. The monies inside the pocket is the 3.48%thanks much
1. main savings account <- this is transfer monies in from other banks and transfer out
2. need to use the app to create pockets (seem max at 8 pockets). then transfer monies into this pocket using the monies in above main savings account. Don't ask me why so troublesome force us use pockets to get 3.48%
The con so far I found
1. dark theme cannot change to white color
2. no save payee function so every time transfer need enter the info
3. max daily transfer limit is 15k
My gut feel is they are making it troublesome for us to do transfer out to prevent mass withdrawal? Hmmm this point need to take note.
I think it's 12 hrs right? After every registration, e.g. new customer, existing customer changing new device.
- How do I set or change my daily fund transfer limit?
When you sign up with us, your daily transfer limit is automatically set to S$1,000. You can change this limit to up to S$100,000 per day. To change your transfer limit on the GXS app, Go to 'Me'. Press 'Change limits'. Alternatively, From the 'Send Money' page, tap the three dots. Select 'Change daily transfer limit'.
You probably can't do today if you just registered as they have a cooldown period of 24hrs.
I very scared of hassle one but I also don't find this too troublesome lah. Just paynow yourself to your favourite bank app.thanks for sharing the info
wah if too trouble I'll skip
just park at gosaver sua
I just registered and manage to update to $75k daily transfer, no 24 hours cooldown period.I think it's 12 hrs right? After every registration, e.g. new customer, existing customer changing new device.
I yesterday evening registered. Just now tried already can changed beyond 15K.
Sorry I think I confused. 12 hrs wait was for my Singpass re-registration yesterday (due to failed face recognition). My bad.I just registered and manage to update to $75k daily transfer, no 24 hours cooldown period.
If change device will trigger cool down period of 24hI just registered and manage to update to $75k daily transfer, no 24 hours cooldown period.
