My AiMesh, with AX6000 as main router and XT8, was doing fine till recently, the XT8s have been disconnected frequently and randomly. My device would attempt to connect to the AX6000 instead of the nearest node. The XT8s are backhaul wired connected.
It seems to be me that XT8s would “hibernate” when there is no active wireless connection. Reason being I’m only aware of the disconnection due to poor wireless performance when I started my online activities. When I check the Asus Router app, it indicates that the connection to the XT8s are down and my device is connected to the router which is a distance away.
I have power cycled the router and XT8s, reset them and re-setup. However my network continues to be plagued by this issue.
Any advice on this? Thanks.
