ASUS ZenFone 10
xonix
How is Esim better than normal telco sim for roaming?
I guess, more so for the convenience that everything can be done online. For me, I actually still prefer physical nano sim cos I can switch it to another phone easily if needed. Not sure how many time those travel esim can transferred. Even domestic esim have a max of 3 or 5 transfers and then it's chargeable.
dappercivility
M1 charges me a few bucks everytime I transfer the esim. Moving backwards in technology seriously.
dappercivility
Anyone got the zenfone 10 yet? Right now export sets are available and if anyone is using the phone, do share your thoughts. Thanks
xonix
2 main reasons, currently not available locally and only 2 yrs of guaranteed OS updates.
Racking2322
No need change SIM card, you will understand the ease if you travel often. Just scan 1 QR code and line is up, no need the line anymore just delete profile.
oh cos i use telco roaming so no need change sim. almost tot esim got faster roaming
dappercivility
Collected the Zenfone 10 in the early evening from Mobile Hardware. The Zenfone 10 can use the case for the Zenfone 9,luckily I did not throw away my Zenfone 9 case.
Everything feels the same but during setting up, the phone gets pretty toasty and laggy, probably due to throttling of the SOC to reduce heat.
Will monitor a few days and update again here. Very compact, light and feels good in the hand. Right now using the S23U to type this post, the S23U feels really huge
chooyoshi
Did it connect to volte?
shager
What's the damage bro? How long did it take for the phone to arrive after you placed the order?
dappercivility
Price is $1050 for 256gb,morning I confirmed, evening arrived can collect as their supplier have ex stock. Need to check with them on availability.
Racking2322
So 9 less heat?
