- Jul 29, 2003
Sim card?Can't wait, then both my lines will have 5G.
Surprisingly my mom's Iphone 14 also dont have 5G with Simba.
Yeah. Sim card. Not changing to Esim. Cos if my sis come back, can pass her the Sim card if she want to travel around SEA.Sim card?
Sorry what I meant, are you using 5g sim cardYeah. Sim card. Not changing to Esim. Cos if my sis come back, can pass her the Sim card if she want to travel around SEA.
For SIMBA or Singtel? Singtel using 5G. Simba not sure, but I got the Sim card in 2022. They didn't mention if need to change Sim to get 5g.Sorry what I meant, are you using 5g sim card
IMHO.
I have been hoping for a long time already.![]()
Having both lines on Simba, 4G+ and 5G NSA, i can say no much difference. Don't expect speeds up to 500mbps. The highest so far i got on 4G+ was 150mbps and 5G NSA was 227mbpsCan't wait, then both my lines will have 5G.
S23 should already have Simba 5G. If you can't see it, likely your area don't have coverage. I was nearby Farrer Park MRT recently and saw it shows 5G on mine.IMHO.
really? will check it out when I'm near Farrer Park. I'm not on Power saving mode though unless battery below 25%.S23 should already have Simba 5G. If you can't see it, likely your area don't have coverage. I was nearby Farrer Park MRT recently and saw it shows 5G on mine.
In case you are using power savings mode, remember to allow 5G. By default power savings will disable 5G.
Ah, so its not that high.Having both lines on Simba, 4G+ and 5G NSA, i can say no much difference. Don't expect speeds up to 500mbps. The highest so far i got on 4G+ was 150mbps and 5G NSA was 227mbps
IMHO.S23 should already have Simba 5G. If you can't see it, likely your area don't have coverage. I was nearby Farrer Park MRT recently and saw it shows 5G on mine.
IMHO.Ah, so its not that high.
Highest I got on Singtel 5G is 852Mbps at home which is as fast as connecting to my wireless router on Wifi 6 at 160Mhz bandwidth.
that's good speed. i do a few of these tests and realise it ate up my data pretty quickly. lol.IMHO.
My new record for Zym 5G.
IMHO.that's good speed. i do a few of these tests and realise it ate up my data pretty quickly. lol.
which area do you stay that you're able to get 5G on your Simba for yr S23?
his location is fbi secret dont askIMHO.
Eh... apologies I cannot disclose my location.
Anyway it is not S23 Ultra. I using the budget of the budget Samsung A14 5G. Makes no difference as now cannot get Simba 5G after the firmware upgrade.
The Zym 5G that is over 1500 Mbps, also the same Samsung A14 5G.
IMHO.his location is fbi secret dont ask![]()
