- Jul 29, 2003
check you SIM status will state for samsung > about phone > status information>sim card statusHi able to check is it SA or NSA network?
I would just live with it for 30 days..Ok to pay for the early port out fee of $30, you need to go down to either kaki bukit or somerset branch to make the payment.
Where you get the 7 days? It's 30 days or pay a $30 penalty.
My daughter smart watch cannot support VoLTE so nobody can call her without using the smart watch app which is a hassle.I would just live with it for 30 days..
I would get a line that supports future port in like Vivifi to use for a few weeks with the temp number, then port the Simba number over after 30 days.My daughter smart watch cannot support VoLTE so nobody can call her without using the smart watch app which is a hassle.
Ya that is one option. Anyway is my mistake not to check properly that her smart watch cannot support VoLTE so I pay for the convenience to get it sort out earlier.I would get a line that supports future port in like Vivifi to use for a few weeks with the temp number, then port the Simba number over after 30 days.
i went to Lim Chu Kang, near Hay Daries last week, the reception there for SIMBA is quite bad, 1-bar or to no reception. Sungei Tengah should be okay according to nperf app. But not lim chu kanghi, i’m planning to port over but i’m concerned about the signal at sungei tengah as my dad works there. anybody can provide any feedback?
Lim Chu Kang has got a lot of "Cannot be seen cell signal towers energy" too! No wonder it is so strong!i went to Lim Chu Kang, near Hay Daries last week, the reception there for SIMBA is quite bad, 1-bar or to no reception. Sungei Tengah should be okay according to nperf app. But not lim chu kang
you can throw away the watch because 3g will end next yearMy daughter smart watch cannot support VoLTE so nobody can call her without using the smart watch app which is a hassle.
Luckily her watch can support 4G LTE. Just not VoLTEyou can throw away the watch because 3g will end next year
Then it's probably not so smart generation.My daughter smart watch cannot support VoLTE so nobody can call her without using the smart watch app which is a hassle.
Nope is a Singapore company called MyFirst which is owned hy Oaxis asiaThen it's probably not so smart generation.
China one?
Yup . Even day time, you can feel the network aura there. They can even use Voym, voice over your mind.Lim Chu Kang has got a lot of "Cannot be seen cell signal towers energy" too! No wonder it is so strong!![]()
Go to Voice and Data. Set to 5G auto.folks i might be dumb, please bear with me. I just ported into SIMBA yesterday, today activated. Using esim and iPhone 12 pro.
i notice that my network is forever on LTE, no "4G", "4G+" or "5G". is this meant to be like that? If not, how do i change it?
