keenklee
If this is the speed for Simba 5G.
It cannot make it and not worth switch over
IMHO.
Should be ok lah. I from cannot use become can use because of 5G.
Anyway, the 4G download speed also improved more than 20x. Maybe alot of users at the 5G now.
infinity2030
just now 10 suddenly no signal, then after few minutes all ok.
maybe in batches don't know do what
Depends on which area you were in, they're probably doing a short upgrading.
kelvinti
Okay. Assuming that you have opted for 5G connection.
Ya! Since the roll out of its 5G, I have experienced 1 to 3 times a day that the SIMBA cell signal totally lost connection in a few frequent spots, be it 5G/4G/3G or voice.
It took about 5 seconds for the SIMBA cell signal to recover with full 5G each and every time. Not a big deal since it is just a 5 seconds loss! Probably that SIMBA is fine tuning its network/infra thus causing the short duration of cell signal loss! :unsure:
My "territories" are between Aljunied and Paya Lebar MRT!
keenklee
Ya! Since the roll out of its 5G, I have experienced 1 to 3 times a day that the SIMBA cell signal totally lost connection in a few frequent spots, be it 5G/4G/3G!
It took about 5 seconds for the SIMBA cell signal to recovered with full 5G each and every times. Not a big deal since it is just a 5 seconds loss! Probably that SIMBA is fine tuning its network/infra thus the disconnections thus the said cell loss! :unsure:
IMHO.
Also could be your mobile issue ?
In my scenario, I think 5G and 4G different base station. Depending on whether I am nearer to the window, the mobile will switch between 5G and 4G. :ROFLMAO:
kelvinti
IMHO.
Now, SIMBA has added 5G to its 4G infra not long ago. I guess this type of issue is common at the initial stages of the roll out period!
keenklee
IMHO.
Previously for a short while, I could access 5G and then couldn't.
Thus the 5G is already there, they just turn it off and then turn back on now.
But good to be positive about it. (y)
kelvinti
IMHO.
Ya! I had the same 5G logo pattern too during the 1st week after port-in to SIMBA but no more since then! (y)
