Youmigratecanotherscant
- Sep 1, 2023
Hi guys. My $39.90 2yr MR contract is ending next month. Can I downgrade the speed to 200mbps after that ? Will Mr charge me anything ?
I just tested as shown below.
Hey kendo21It works, after activating my static IP, i immediately switch to dual wan. My 2nd WAN start to lease in 24hr instead of 10mins.
Hey kendo21
do you think you could list the hardware you used to get the dual wan load sharing?
I'm thinking of using the Omada ER605 router + 1 static IP.
anyone connection to AU suck now?
I was thinking of something better, but i realize that most of my hardward don’t have 2.5G. Even my X60 Deco only has gigabit ports. But the ER605 Omada should be able to load share from MyRepublic modem right?He is using Asus RT-AX86U (initially with Singtel 1+1, and later MR 2 Gbps plan).
I tend to think Qomada ER605 is not a very good choice as it does not have 2.5G LAN port.
The better choice is probably mini PCs with two or more 2.5G ports, then you can run pfSense or OPNsense or OpenWRT. They are better than the Asus for Dual WAN Load Balancing.
normal - 90msVPN to Sydney and run speedtest result:
ping 186
DL 771.71
UL 47.13
looks okay
Help !!!
just got my MR 10Gbps installed today... tested by the techinian at ONT was 8000+mbps...
but when connected to TP AXE300 router... only get 3300 DL, 290 UL....
pull a direct CAT 6 cable (15m) from ONT to router... also same..
what went wrong? TP link router issue?
If you head over to the New 10Gbps Plan thread, you'll see a lot of bros also have the same issue. Same thing happened to me right after installation. But the speeds seemed to stabilise a week or so after that around 8.2-8.4Gbps u/l and d/l. XGS-PON plan tend to have more overhead so won't be able to get 9Gbps or higher.Help !!!
Got try using another DNS server (Cloudflare/Google/Quad9/etc)?I subscribed to MyRepublic 1Gbps plan a few days ago and i keep noticing that the internet disconnects something like every 15 minutes.
Error message in Chrome:
No Internet
- Try Checking the network cables, modem and router.
- Reconnecting to Wi-Fi.
ERR_INTERNET_DISCONNECTED.
I learnt that if you hit refresh or just wait 10 seconds, internet connection will come back again.
Connection is from Nokia ONT -> TP-Link EX510 WiFi-6 Router -> Apple Studio using wired LAN cable.
It is especially irritating on MeWatch which totally kicks you out and you got to reclick again, only to get kicked out after a while.
Anyone got the same issues and know how to resolve?
That the same issue i am encountering, Your ONT is red lighting and resetting itself.I subscribed to MyRepublic 1Gbps plan a few days ago and i keep noticing that the internet disconnects something like every 15 minutes.
No Internet
