Detected mobile Google as virus
NightGhost
I guugle also … it says the Google virus alert is a fake! … a scam trying to trick you to click some link or install some .apk which will steal your info
It just asking me to uninstall. I thought maybe Android version 12 is end of support for my mobile, maybe
So far i check my phone not yet support Android 13 n no update
NightGhost
huawei, honor , no google app right ?
install 3rd party apk sure problem
Go to Google play store and download the Zoner Antivirus app, do a initial run to scan for threats.. if the results are clean, it will mean that you are safe. Otherwise it means your Google app is not the true stuff. It's a malware..
Google play store say tis app not available for my device. It's made for an older version of android
Dunno if yours is legit Google app, but it would not surprise me from a china manufactured phone perspective, American software is regarded a virus
My phone was the last batch come with google store before it get ban
XuishX
Anyone Android phone like Honor, huawei or others detected virus alert on Google? Asking for uninstall.
It detected as virus TrojanSMS-PA. Danger level: High
You install unauthorised third party app?
wongminmin
safe anot?
wongminmin
I'm seeing a lot of reports from users of Huawei and Honor devices have reported that their phones are incorrectly identifying Google apps as Trojan malware, specifically labeled as TrojanSMS-PA. According to the alert, this "malicious software" has the ability to send SMS messages without user consent.
On user forums (Reddit, Google Support, and numerous others), multiple accounts support that this is not an isolated incident. The issue seems to have appeared after the latest Google app update and is primarily identified by Huawei's own Phone Manager or Optimizer app.
Other antivirus apps like Norton and Sophos did not identify the Google app as malicious, which leads to the strong assumption that this is a false positive. While no official statement has been given by Huawei at the time of writing, the general consensus is that this is a bug in Huawei and Honor's security software, rather than a genuine security threat from Google.
One of the most probable reasons behind Huawei's false security warnings could be a software glitch. It's not uncommon for bugs to interfere with security algorithms, leading to inaccurate notifications. Another angle to consider is the role of false signatures. Security software hinges on virus definitions, and an outdated or flawed signature could be the culprit behind the incorrect identification.
It's worth noting that this virus alert was first reported almost two days ago (early October 27), so it is strange that it wasn't immediately addressed by either parties as so many people are having issues with it.
titusilvering
How ah? Now i suspect i kana ccp spying me and use my phone sms scam.
titusilvering
saw a fix from reddit,
I found a way to fix it, clean cache of the optimizer app helps.
Settings-apps-optinizer- stop optimizer - cache and data clean - start optimizer
And than all works fine
I doing that now!
Not working! Lol
NightGhost
Now buy phone may need to buy anti virus as well like pc. If no protection jialat liao.
K202020K
I have free apps from Google play store, one for malware detection and another as firewall. Been using Zoner Antivirus since Day 1 for detection of malware & monitoring silent app updates carried out by Google. NetGuard free download as firewall to block the data traffic for many apps including Google Keyboard.
K202020K
I avoid Huawei products because their apps eg. for fitness tracker are exceptionally overwhelming in size. Easily a few hundreds of MB taken up from storage space. Why they contain so much codes? ... and for what unintended purposes? For data mining job??
Iandao
I received this msg on my huawei awhile ago :s22:
hermes76
got it on my Mate 20X also....uninstalled already Google still can work.
Also noticed a empty icon at the 1st app of the apps drawer, removed that also. so far so good. was receiving random ads like Zalora pop-up earlier on....
almost go factory reset my phone again....
Cowbellc
