aw1007
- Feb 21, 2005
All Telco sets 3 months , the rest 24months.should be 3 months trial only,
https://www.oppo.com/sg/events/oppo-partnership-with-google/
Can i ask if the tempered glass is glued to the case protector? Or is it a seperate item? If it is glued, did you remove your original front screen protector before you put on this case?
Accessory lor, feel safe, also some case with feels better to grip on.
Not glued. It is a tempered glass screen protector and just rests on the screen perfectly with no bubble. And yes, the manufacturer advised to remove existing screen protector.Can i ask if the tempered glass is glued to the case protector? Or is it a seperate item? If it is glued, did you remove your original front screen protector before you put on this case?
Oppo sales staff in the store and the support team from Oppo have been giving a lot of conflicting responses...I don't even know who to trust anymore. The most prudent thing to do is to be cautious in the way you handle the phone. So long as it is not due to negligence, Oppo should honor the repair/replacement of parts or screen protector. No need to be overtly worried about all these things, start to enjoy using the phone. That's why you bought the phone in the first place.i say if the damage is due to my fault or water ingress or wat nonsense , will it void this 2 year warrenty. abit extreme to make my point la ...
I asked it cos i seen in the other sub forums , knn service center say the spine a bit scratch or wat nonsense to reject inner screen claims.
but the oppo sales like confident only, say any damages.
if this is true , why yall bother with the thick protection , unless some of you like to flip it after some months usage or when next version is out ?
Agreed...the new case I'm rocking does add a heft to the overall weight and I definitely can feel it. We are always in a dilemma when it comes to protecting an expensive foldable phone vs going "naked" and risking getting dink from accidental drop and bang. This will eventually affect the resale value when we decide to trade in the phone.I must say it feels real good to use naked esp the black version as there is some grip
For your experience does the online support seem to be a lot better than your experience with the service centre? The service centre is quick to decline and deny service in my experience.Oppo sales staff in the store and the support team from Oppo have been giving a lot of conflicting responses...I don't even know who to trust anymore. The most prudent thing to do is to be cautious in the way you handle the phone. So long as it is not due to negligence, Oppo should honor the repair/replacement of parts or screen protector. No need to be overtly worried about all these things, start to enjoy using the phone. That's why you bought the phone in the first place.
To disable Google feed at home screen, disable Google app and reenable it.
can i ask if u removed the existing screen protector? and do you feel any difference if you didnt?Not glued. It is a tempered glass screen protector and just rests on the screen perfectly with no bubble. And yes, the manufacturer advised to remove existing screen protector.
somehow it will peel off by herself for most ah tiong phonecan i ask if u removed the existing screen protector? and do you feel any difference if you didnt?
Im just hesitant to remove it if i get this case![]()
You can just change the back and keep the existing front case. It will work and look similarcan i ask if u removed the existing screen protector? and do you feel any difference if you didnt?
Locally can only find 30W which is the white version. Got this 50w one from Taobao and Supervooc charging works on N3 (https://m.tb.cn/h.5QEhrwh?tk=HcZTW3Ws84e)Hi folks, any power bank that is supervooc 67w for find N3? cant find any in Shopee / Aliexpress..
Can i know where did you see this?![]()
Seems like there's a new trade up promo.
their facebook. also passed by the concept store at suntec and there's an ad there too.Can i know where did you see this?
