Singapore Savings Bonds
BBCWatcher
I can apply using SRS using 5k and cash using 5K? Meaning two transaction?
You can if you wish. That’ll be $2 per transaction, so $4 total.
Are you sure you want to use SRS funds for SSBs? Unless you’re at least somewhat near your planned first withdrawal age it’s usually better to pick a longer term investment vehicle.
magicming
Yes. But do remember that if allocation is very low, say $9k, then your first application will be fulfilled first. And the second one only partly, $4k , in your example.
ekardo
Oh, it matters which application to apply first. (For cash and srs)...I am also planning to put both.
DenOOO
Withdrawing everything except for Dec 2022 issue and pumping $185.5k, hope for the best !
