Oppo Find N3 | Find N3 Flip
maumu
Trade in value to buy Oppo Find N3!!!
thanks for the sharing. strange that when I went to the store @ suntec.. the guy showed me the trade in for x6 pro is only $500...
so I guess the "overtrade" is only $175. maybe the n2 flip enjoys the full $200 overtrade.
it's a bit low especially for the powerful x6 pro. trade in value only $500 without the overtrade 😪
on another note, the black leather version is really darn feather light. anyone using this phone naked so as not to add bulk/weight to it? feels tempted to do so (if I ever get it).
divinepotato
My Google alarm clock doesn't go off at all.
Set a bedtime routine from 12am go 7am and the alarm is supposed to ring at 7am.
I didn't use the stock alarm clock because it cannot increase the ringing gradually.
My Google clock works perfectly. Maybe you can try reinstalling.
zapp!
Hi, can I check if there is anyway to make the camera timer use the led light? I can't seem to find it in settings.
shinoku2
Got my n3 flip and will like to check if anyone removed the original screen protector to replace with tempered glass?and currently is there option to insert Google chrome in cover screen? Seems that there is limited apps in cover screen
ra[g]e
can i ask if u removed the existing screen protector? and do you feel any difference if you didnt?
Im just hesitant to remove it if i get this case :LOL:
I didn't remove the stock SP, no issues with sensitivity at all.
I bought direct from Taobao so maybe diff stocks from the peeps that bought from Shopee.
However it's not matte type so there will be a bit more reflection under certain light.
Ray1976
Did you enable notification for your clock app? It needs to be enabled for the alarm to work.
kogregory
Anyone know if I walk in to any Oppo store & purchase at $2399, will this price include the free earbuds & 24mths screen protection?
fatesealer
If anyone is still wondering if the camera is that good. This is taken with the lousy lens protector on. Imagine without it!
kogregory
Anyone can share. If I'm buying from a handphone shop, how to know if it comes with the 24mths screen protector warranty?
