Xiaomi vacuum robot users lip lai please
Spheredome
Ecovacs t9 app sux
if u lose wifi connection, or robot stuck
map will also need to remap
u need to phsyically relocate the damn whole thing to another area in your house
and the map will go back to normal
stupid vacumn also can get stuck, if the damn vacuum can enter this area why u cannot get out of this area
useless software
Yes unfortunately, Ecovacs is very demanding for good wifi coverage, else the map lost issue will be frequent. T9 LDS and positioning is real-time even when carried, so locating should be pretty fast within 3 sec the moment you put on the floor. However to ensure all these, the home wifi must have all coverage, at least a 3/5 bar for stability. This is something Ecovacs cannot fix over the years for all models.
The issue which I believe is their backend system which their dynamic update is also the cause for map corruption.
jt00201
Hi, anyone using mijia mjstp and faced problems of robot constantly notifying that it is stuck even though there are no foreign objects in the wheels or brush?
stetan
If order the Dreame L30 ultra from Amazon, will it work in Singapore?
Dreame L30 Ultra Robot Vacuum and Mop, 136°F Hot Water Mops Self-Cleaning, Mops Self-Drying, Mops Extend, Removal & Raising, Self-Refilling, Auto-Empty, 7,300Pa Suction, AI Action and 3D Navigation https://a.co/d/9yXVTcj
Spheredome
Every brand models with auto empty bin motor runs on direct current so voltage is either 120 or 240V. So L30 or equivalent sold in Amazon are likely 120V. Same goes for any form of vacuum cleaner, iron and coffee maker.
Models with only mop wash tank may be usable because they runs with adaptor to DC with range of 120-240.
LiLAsN
If you guys are interested in a cheaper version of the Dreame L20 Ultra with the same features such as the swing out mop for closer to the wall mopping, Roborock has just released the Q-Revo MaxV.
It's white in colour.
Edit: Finally found the link to the Shopee/Lazada post. Originally saw it as a Facebook sponsored ad post.
https://shopee.sg/-GRAND-LAUNCH-Rob...-Brush-Mop-Hot-Mop-Wa-i.126007714.25801826131
https://www.lazada.sg/products/gran...-3d-ai-mapping-i2945519220-s20256829338.html?
It will be a way cheaper alternative with probably better suction than the L20 Ultra which may place it above the Dreame L20 Ultra.
Toiletpaper80
Apart from dreame, what other robot is able to auto refill water and remove dirty watrler?
fade_white
When you are still pondering to buy Dreame L10 or L20, Dreame China has launched their model 30. Model 30 comes with roller brush hair cutting feature and a self scrubbing washing bin.
Roborock China launched the P10 Pro sub model with auto extend mop pad for edge cleaning.
is p10 the same as q -revo max v?
Nakedtoes
The Chinese p10 app got function to turn the robot to mop the edges of the wall.. The gobal app no have.. Hope can bring this feature to global.
stetan
But it does not have auto water kit ….
Vulpix
Moderator
Moderator
Find from Taobao? Some of the 3rd party parts like not working as good as the original ones.
Well, some things need to compromise on quality. But you must be selective in what to compromise. Mop pads why need super high quality? Spoil just throw. But things like filter will affect your unit, so might not want to go 3rd party.
You have to decide which part you want to save on.
Spheredome
For myself, I buy original from TB flagship for brush and brush cover because most generic are more noisy because of the plastic use. Filter and detergent, I use generic brand. For mop round pad, I am selective because I prefer some of the oem design better than original. Like I prefer fluffy one over those with blob mop hair type. Battery, most of time no choice except to buy better feedback ones. Sometimes those claimed original are not.
Ironside
Remember to take out and wash the roller, then clean the inside of the robot properly. If not, 吸了不会干净,抹了也不干净。
zhiming1
Dreame is geolock. If you do not see people mention model here, it means lock. So are most models now, including Narwal.
i got Narwal J4 as a gift from china. I manage to fix the geolock, able to add it to the App. If anyone is interested to know, just PM me
Narwal J4 is the latest version. Narwal Freo = J3 in china
Spheredome
What is a no frills sweeping robot for parents? Preferably less than $500-600.
Except Ecovacs (map corrupt issue). Xiaomi are ok. Only buy those with spinning Lidar. If you want remote control, then have to got with old series ILife A10, but lifespan questionable.
stetan
The new Dreame L10 ultra PRO Heat seems even better than the L20 but at a cheaper price
It has also extensible mop, hot water mop and hot water mop washing....
bladez87
How does xiaomi s10 compare to s10+ and viomi v2 max? 4rm hdb, vacuum only, not using mop function cause of mold issues.
These 3 models are within my budget. Thanks
iteo74
Go for Roborock? Maybe one of the order models like S8. I have not used before but given popular sentiments on Roborock, it'll unlikely be wrong. I saw this on Lazada and should be going under $600?
Check out Roborock Q8 Max Robot Robotic Vacuum Cleane...at 56% off!$569.90 only!Get it on Lazada now! | https://s.lazada.sg/s.YV1m7
I myself am a Ecovac T9 user. I know a lot complain about its map going off when the WiFi connection drops. I suppose I am a lucky one and have very few experiences of that.
I am waiting to try Roborock Q Revo or later model but so far robot still going well after 2yrs so can't justify spending but its always in my shopping cart hahahhaa
