BlackWing1977
- Mar 1, 2006
Your pressure too much... to switch from multi-blades cartridge razor to DE need some time to unlearn all the shaving habits... like applying too much pressure to shave... and watch the angle... follow the contour of the face.. and to be safe.. do it in 3 passes... follow the grain, across the grain, then against the grain..i quite often get cut from the DE. so changed to 4 blade titanium coat one liao. no regrets.
If your beard is extra thick.. can use warm towel to heat up first... or apply some sort of pre-shave.
