Simply go sucks
luckyplate
Why don't just simply died .
. simply died better ..no need to take mrt .
Anyway .. simply go maybe another ah loong plan
To tax
bangzhou
How about those elderly passion card that can be used for public transportation? Need to upgrade to simplygo as well?
David Lai
most, if not all concession passes for seniors, adult, children, students and workers are not affected, it seems…
unless zaobao reports it wrongly…
Gian_Png
most, if not all concession passes, senior, adult, children, are not affected, it seems…
but these are govt issued cards leh?
technically if affected, they should proactively do replacements for citizens right?
AuraKUPO
Do not forget to top up the card till negative value, it becomes useless.
One of my SimplyGo card had this issue, now it is not responsive. Need to tap more than 5 times to get the successful tap.
I didn't try tap 5 times. I tap once cannot already. Go to the driver or control station, they ask me to wait for a few days for the server to update and let my card be usable again
Lustgan
What u mean? If kenna nagarive then spoil the card?
megaweb
Yes, I did that but the card issue not resolved.
megaweb
Look like they have set a flag in their system to prevent me using the card. Anyway I heard now the card has less than $3 , you cannot use it as it will show your error.
Lustgan
Gosh so troublesome seriously…
