Xiaomi 14 Ultra
SecretAgent
China ROM version tends to leave out e-SIM.
default universal esim is not in any 14u.
but these is this mi-sim, mi roaming and mi mobile thingie... it is Xiaomi esim within the phone. it is cn handset hardware features too. it is quite cheap with free data . I think it got roaming features too. only if you are a frequent traveller and can make payment in cn too.
i think this is a cn handset unique features.
Sg useless for these.
SecretAgent
I just went by Suntec store confirm don't have. That makes 3 stores not having it At this moment I don't think the 14 ultra display sets will be in till at least PO period is over.
what do you want to know about the phone?
DrMax88
FYI, this is not correct, reviewer didn't check properly
inside camera grip settings, there is a toggle, "grip charging auto-disconnect"
description reads "when your device recognises that you're using a camera grip, device will stop charging and keep battery at 80%"
According to reviewers, that setting doesn't take effect. Future update might fix it though.
DeepseaG1523
thanks for the info.
Am I right to say if u using this phone for constant phone taking, video taking etc, the phone battery starts to drop below 80%, the 1500mAh power inside the grip will start charging and soon the grip battery will be gone? which then make the grip unable to use anymore?
SecretAgent
Nothing just wanna hands on and play with it hahahahaha
I give you some of my 0.2cents opinion on the physical feel.
Mine is cn version ceramic blue. Heavier than Kona leather black or white ones. This is a thicker phone than 13u. The design and weight distribution on whole makes it very easy to handle on the hand(one hand) for normal usage. It is not top heavy to make it feels like it will easily flip dropping back down .
Of course, the camera island is big and protruding but this is why we choose ultras, it is a phone on a camera!
I heard they are starting to sell the titanium version in cn now. This one is more expensive
Moguls
Suspended
blue colour one won't get dirty easily
White colour leather can get scratched
Black colour one is plasticky feel
Conclude blue one way to go
SecretAgent
... for me...
this phone is still pocketable even with photography kit on... the battery of the kit is a boom!
