Heat pump water heater
sacredrays
like your aircon lor.. but in reverse.
got heat pump clothes dryer also, which is ventless.
cantona81
Cus saw the $300 voucher to use for electrical appliances specify for heat pump water heaters but can't seem to find much info on it
Read HWZ Forum Rules!
that article was from yr 2016... until now still not popular... there must be a reason. can be due to cost or easily spoil or takes a long time to make the water hot, or some other reasons... have to search deeper maybe can find the reason...
ksapple
Heatpump is not cheap is very ex I think daikin has 1
In SG case is link tgt with aircon
cantona81
link with Aircon? means Aircon got turn on the water will become hot? then during cold weather, when u need hot water the most, nvr on Aircon how? during hot days u on Aircon, but how likely will u need hot water on hot days?
neutralph
Water heater also have but not cheap. Btands like asobath and rheem have.
cantona81
but heat pump isn't it supposed to save energy by using heat from other existing heat source to help heat up the water? so my question above is how does it work exactly? it's like last time Stephen Chow's movie 007, they have the solar powered torch light, the torch only works when there's sunlight...
nachtsid.er
Moi use massive aosbath heat pump water heater , switch on aircon every night for 5 hrs, Dryer use everyday .
Total bill abt 170-200 every mth
zueinder
just remind yourself of how expensive the electricity bill is every month before bathing then immediately will feel hot. No need heater liao, settle.
virtualape
https://www.aosbath.com/micro-heat-pump-water-heater/
damn ex sia.... not sure if the electricity bills saved can cover the cost of the heater...
Can calculate the electricity usage of normal heater vs this. I have a feeling need at least 4-5 years to cover the costs.
Normally my side is on for a total of 1hr daily. Estimated $360 a year. 3.3kwh x 30cents pwh. Need 8 yrs to cover the cost of heat pump heater :ROFLMAO: :ROFLMAO:
HMAN
heat pump dryer with accurate humidity gauge is good, perfect dry without wrinkles..
it takes longer time to dry but won't damage your clothes with over heating.
DragonFire
Cost is an issue. As much power as it saves they have a big upfront cost.
That said, for sheer performance you won't find better. I have a light commercial unit installed and I'd never go back to regular instant or tank heaters.
They can be augmented to receive solar heated water or water heated by an air conditioner heat exchanger, thus reducing power bills even further.
DragonFire
Quick comparison.
Instant heater
- cheap
- saves power (varies with usage)
- low flow rate
- hot water on demand
Tank heater
- cheap
- eats power (varies with tank size/design)
- excellent flow rate
- preheat required if in power save
Heat pump tank heater with booster
- expensive
- saves power when operated within design limits
- eats power if undersized
- cools the room the tank is installed in
DragonFire
The daikin heat exchanger is meant to supply another suppliers tank heater with preheated water. It is meant for use with VRV installations. I explored installing one, but my ME space was too limited.
