Any sexpert can advise what is a heat pump water heater? What is the diff with those storage heater?
Read HWZ Forum Rules!
https://www.todayonline.com/singapo...g-use-heat-pump-water-heaters-singapore-homes
from this old article, it says it heats up the water by absorbing heat from environment, thus uses less electricity.
Cus saw the $300 voucher to use for electrical appliances specify for heat pump water heaters but can't seem to find much info on it
Heatpump is not cheap is very ex I think daikin has 1
In SG case is link tgt with aircon
i change from storage heater to heat pump water heater. Difference no tank but water heat up not as fast as instant water heaterAny sexpert can advise what is a heat pump water heater? What is the diff with those storage heater?
Water heater also have but not cheap. Btands like asobath and rheem have.link with Aircon? means Aircon got turn on the water will become hot? then during cold weather, when u need hot water the most, nvr on Aircon how? during hot days u on Aircon, but how likely will u need hot water on hot days?
Aos bath $2.9k for 80 liter tank. If have 50l at much lower price, I'll buy one.Heatpump is not cheap is very ex I think daikin has 1
Can calculate the electricity usage of normal heater vs this. I have a feeling need at least 4-5 years to cover the costs.https://www.aosbath.com/micro-heat-pump-water-heater/
damn ex sia.... not sure if the electricity bills saved can cover the cost of the heater...
Cost is an issue. As much power as it saves they have a big upfront cost.that article was from yr 2016... until now still not popular... there must be a reason. can be due to cost or easily spoil or takes a long time to make the water hot, or some other reasons... have to search deeper maybe can find the reason...
The daikin heat exchanger is meant to supply another suppliers tank heater with preheated water. It is meant for use with VRV installations. I explored installing one, but my ME space was too limited.Heatpump is not cheap is very ex I think daikin has 1
