I think HV will be priced similarly to Ghim Moh BTO which is close proximityI was referring at HV
OOTI think HV will be priced similarly to Ghim Moh BTO which is close proximity
Ghim Moh BTO was starting from 516k so don’t think HV nearby will jump to starting from 700k
I think it be slightly higher or with higher clawback percentage of 8% but don’t think it will start from 700k
Maybe feedback wasn’t good hence they introduce the PLH clawback system to keep starting price lowerOOT
Still don't understand why the starting price of $600k for telok blangah beacon back in May 2021, I think it was the only project in that year with such a high base price
Before the implementation of PLH
But connectivity is bad. Going to woodlands or marsiing mrt by bus need at least 20mins on average.Woodland BTO directly opposite the Marsiling market…amenities not bad
Because telok blangah is nearer to city area. Hence worth more. Hdb got some algorithm based on distance to central so for instance, clementi is worth more than Jurong east in terms of hdb calculation.OOT
Not 100% true, for example ulu pandan banks 4room is from 546k compare to havelock hillside 4room from 531kBecause telok blangah is nearer to city area. Hence worth more. Hdb got some algorithm based on distance to central so for instance, clementi is worth more than Jurong east in terms of hdb calculation.
They also have other algorithm like dist to mrt, how many years to completion.Not 100% true, for example ulu pandan banks 4room is from 546k compare to havelock hillside 4room from 531k
Havelock is a lot nearer to city centre compare to ulu pandan but ulu pandan banks was more expensive
OOT
What are the odds of the Tanjong Rhu project having balconies for the 4-room units? With such a view and high plot ratio, it'll be a waste not to have any.
There's those facing sports hub and will be unblocked based on URA's master plan. I think that's a pretty good view.All the sea view one will be blocked, what's the point?![]()
Ghim moh bto > holland village btoTanjong rhu bto quite attractive cuz near city, but sea view facing will confirm be blocked as there is another residential plot in front. But overall still very ulu unless u have car, otherwise ur walk to MRT is a shaggy 10 to 15 mins to TEL.
Holland V also not bad but will be over shadowed by very tall condos like one holland and also the ghim moh BTO. Very convenient to alot amenities, but can get crowded and will take a bit longer to get to the city via MRT compared to the other queenstown and bukit merah BTO.
