- Sep 16, 2018
1. Link speed is pretty good, 6G Link speed is even better than previously posted.
1) 6GHz link speed is superb.
TX --> 5764 Mbps --> 2x2 BE 320MHz, 4906 QAM, this is the max link speed
RX --> 5187 Mbps --> 2x2 BE 320MHz, 4096 QAM max link speed is 5764 Mbps. This is close.
2) 5GHz link speed is on the low side but still decent. Maybe the 6GHz link affects the 5GHz link (not so sure)
TX --> 1200 Mbps --> 2x2 BE 80 MHz, 1024 QAM. This is below the 2882MBps theoretical max (2x2 BE 160MHz, 4096 QAM). The router even supports HE240 but no so sure if any WiFi 7 clients supports that as of now (except 5GHz-1 and 5GHz-2 MLO operation).
RX --> 648 Mbps --> this is even lower than TX.
3) 2.4GHz link is normal
2.4GHz is just too congested for typical Singapore households.
2. Theoretical max for the EB810v router and typical 2 x 2 BE client
1) EB810v BE22000 Tri-Band Wi-Fi --> router is 4 x 4
• 6 GHz: 11520 Mbps (802.11be, 4x4 BE 320MHz, 4096 QAM)
• 5 GHz: 8640 Mbps (802.11be, 4x4 BE 240MHz, 4096 QAM)
• 2.4 GHz: 1376 Mbps (802.11be, 4x4 BE)
2) 2x2 BE client (without considering MLO) like flagship Android phones
• 6 GHz: 5764 Mbps (802.11be, 2x2 BE 320MHz, 4096 QAM)
• 5 GHz: 2882 Mbps (802.11be, 2x2 BE 160MHz, 4096 QAM)
• 2.4 GHz: 688 Mbps (802.11be, 2x2 BE)
