Ceiling fan blade falls shortly after S’pore resident leaves bedroom with baby, he requests compensation
fortunecat
How does Fanco's explanation even make sense, must install exactly in the middle of the room then ok?
pohw0008
Because there is always a safety distance between the fan blade and wall.. usually about 50cm.. same with all ceiling fan.. because the wind is very strong.. the wind hit the wall will bounce back and cause recoiled.. then the wind will cause the fan spin to wobble? but this case could be also due to material..
106gunner
Seller won't compensate one lah unless under warranty.
Seller can say owner improper use or cleaning or hire wrong contractor to install lol
No such thing. Sold defect Fan is can replace. Arbo Complaint to SCT or Case.
fortunecat
Because there is always a safety distance between the fan blade and wall.. usually about 50cm.. same with all ceiling fan.. but this case could be also due to material..
That's just a general guide in case someone really install too close to some structure. But even if so, how does off centre relative to the room cause this?
pohw0008
Think his safety distance only 10-20 cm.. too near the cabinet.. like i said too near cause wobbling.. unstable..
fortunecat
I mean the guide is for incase the fan hit something. If never hit anything, it's not going to cause anything just because it is outside the safety distance
Firstclass1188
Wow where did you study your english and aerodynamics? Seems like gibberish.
pohw0008
That's why it's working for a few years ma.. until unlucky.. too much wobble then the blade hit the ceiling?
sickoflife
There are at least tens of thousands fanco fan installed in SG. He’s just suay lah
bobo07
Fanco workers should come out and whistle blow just like what happen to Boeing….. how can a fan be so LAOYA …..
Laguna123
Following the inspection, the technician informed Mr Ong that the blade detachment occurred because the fan was “off-centre and too close” to the wardrobe.
If fan in the middle of ceiling will blame the lizard for standing too near the fan?:crazy:
standarture
No pity for ceiling fan users. And it's not like they test each product for 1000s of hours.
