GeSteSoh
- May 27, 2010
Curious doesn't this suck battery life by forcing only stand alone 5G.Go into developer options and under 5G network mode. Select SA(prefered).
Will still switch network. No impact in battery life till now. Infact the battery life of this phone because of the big capacity and running china rom is phenomenal.Curious doesn't this suck battery life by forcing only stand alone 5G.
Yeah, battery life is insane for this beast. 2-day use for a charge is definitely doable.batter life is wicked, base on my own usuage, last time s24ultra can only last me till 4pm if i dont charge at all, this phone can till 10pm... all from 6am unplug
Would like to check, do you installed apps other than from playstore?Hi all, wanna to check something about Google wallet.
I tried to add in Maybank Credit card, ezlink wallet master card, which work on S23Ultra, but failed on XF3P. But HSBC credit cards are okay, is it normal? Would like for checking your experience
Same some of my DBS cards cannot too. Other phone same card no issue. Might be some cards are sensitive to China rom with google play. Basically it is basic GMS and not full GMS.Hi all, wanna to check something about Google wallet.
Thanks, then I have to reinstall and reboot to try.Nth wrong with my paylah app.
Yes, there is some China apps installed from vivo store. Like pinduoduoWould like to check, do you installed apps other than from playstore?
China rom. Location history, auto, wear pay....... Will not work.Anyone with the phone can confirm whether google location history works?
