Vivo X Fold 3 Pro
Gadgetfreakloh
Curious doesn't this suck battery life by forcing only stand alone 5G.
Will still switch network. No impact in battery life till now. Infact the battery life of this phone because of the big capacity and running china rom is phenomenal.
Exaita
batter life is wicked, base on my own usuage, last time s24ultra can only last me till 4pm if i dont charge at all, this phone can till 10pm... all from 6am unplug
aw1007
Yeah, battery life is insane for this beast. 2-day use for a charge is definitely doable.
GeSteSoh
Nikilin Vivo XFold3 Pro case, the green colored phone top cover, the front half cover, it does not fit completely. It does not cover the top and bottom edges of the front screen well. You have to physically press on the case and yet it doesn't fit. Compared to the black version front half cover, it fits completely and comfortably. :cry::confused::oops:
Already emailed their CS.
xifuga
Hi all, here is a NEW issue or bug.
DBS paylah app, always crash for 7 or 8 times, then works.
xifuga
Hi all, wanna to check something about Google wallet.
I tried to add in Maybank Credit card, ezlink wallet master card, which work on S23Ultra, but failed on XF3P. But HSBC credit cards are okay, is it normal? Would like for checking your experience
aw1007
Would like to check, do you installed apps other than from playstore?
Gadgetfreakloh
Same some of my DBS cards cannot too. Other phone same card no issue. Might be some cards are sensitive to China rom with google play. Basically it is basic GMS and not full GMS.
xifuga
Yes, there is some China apps installed from vivo store. Like pinduoduo
And few app installed during data transfer via EasyShare
Exaita
update again unless i slow
aw1007
Not encountered such issue since day 1...maybe is due to my habit of powdered down my phone every nite before sleep.
winningeleven
This phone is going to launch in India in 6 June . So there will be a global version available?
UnlimitedBladeWorks
how do switch to silent mode (only vibration, no sound notif) when using focus mode? want some app notification to come in but silenced. tried searching but cant find solution
