Yongkit
- Oct 9, 2015
The new Asrock MBs are looking really nice esp. the Nova.
I am interested for something similar to ASRock X870 Riptide WiFi as it have 4 slot nvme gen 4 compatible
The ASRock X870 Riptide WIFI of the Phantom Gaming series features a 17-phase power design, a single PCIe Gen5 X16 slot, and only 3 M.2 slots (1x Gen5 + 2x Gen4). This board is aim to be more budget-friendly in the absence of more, higher-end parts.I am interested for something similar to ASRock X870 Riptide WiFi as it have 4 slot nvme gen 4 compatible
If all the nvme slots are coming direct from the CPU, the max is 4 slots (while leaving x8 for GPU), CPU got 28 lanes of Gen5, 4 lanes is used for I/O chipset(s) leaving only 24 lanes, so 8 (GPU) + 4 (nvme) + 4 (nvme) + 4 (nvme) + 4 (nvme) is possible. Gigabyte X670E Aorus Xtreme has this configuration.Any x870 boards with at least 5 nvme slots? My current board has 5 nvme and 7 sata ports
What about pcie4 nvme slots? I don't really mind not having pcie5 nvme.If all the nvme slots are coming direct from the CPU, the max is 4 slots (while leaving x8 for GPU), CPU got 28 lanes of Gen5, 4 lanes is used for I/O chipset(s) leaving only 24 lanes, so 8 (GPU) + 4 (nvme) + 4 (nvme) + 4 (nvme) + 4 (nvme) is possible. Gigabyte X670E Aorus Xtreme has this configuration.
If you are using chipset I/O, there is a bottleneck as chipset to CPU bandwidth is only Gen4x4, if you plug one Gen4x4 SSD into the chipset, all bandwidth available on the chipset is used up.
Asrock X870 Nova.Any x870 boards with at least 5 nvme slots? My current board has 5 nvme and 7 sata ports
I'm asking for something equivalent to my current mobo. It's a z790 msi wifi edge with 5 pcie4 nvme and 7 sata ports. I thought amd high end chipset should at least match that config
I really hope that is not the case as that will take up 40Gbps of the 64Gbps available on the chipset link to the CPU (multiple high bandwidth devices connected to the chipset will be fighting for bandwidth).The x870 usb4 seems to take up one gen4x4 from amd spec sheet, and usb4 runs through shared chipset lanes
Intel for the deep walletIntel wins in the highest power consumption. Some people like this.
AMD wins in gaming performance. Some people like this.
But.. intel is the best.
Zen 5 is looking pretty impressive ....
AMD has become the Intel of our generation, there's a reason why no price release yet.Probably going to gouge us.
